20 Most Recent Akai CFTD2083 20 in. TV/VCR/DVD Combo Questions & Answers
Turn off the device connected to the av output, then turn TV off and on again!
Akai CFTD2083 20... | Answered on Aug 05, 2015
0279,0285,0291. Try these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Akai CFTD2083 20... | Answered on Jul 10, 2014
you will need to use the RCA inputs at the back of the TV (yellow red and white plugs), if the DVD player only has a SCART connector you will need to get a scart to RCA cable.
Akai CFTD2083 20... | Answered on May 15, 2014
I believe you either have a problem with your Power Supply inside your TV from a defective component in the circuit or you have a problem with the Picture Tube on your TV. I don't recommend you working on TV's by yourself unless you know what you're doing since you can get badly shocked. You need to discharge the Picture Tube on the TV before you work down any further. If you don't know what you're doing then you should get someone that knows what they're doing to work on your TV.
Akai CFTD2083 20... | Answered on Apr 24, 2014
You don't have a cable connected right. Check alll your input connections and also check what they are connected to.
Akai CFTD2083 20... | Answered on Mar 15, 2013
videocon 20 tv asm serch fine lock help
Akai CFTD2083 20... | Answered on Nov 22, 2012
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Akai CFTD2083 20... | Answered on Oct 17, 2012
check and replace your horizontal output transistor as well as the regulator..
Akai CFTD2083 20... | Answered on Jun 12, 2011
Strictly speaking, analogue no longer exists. if you are accessing channels through an Antenna, You're going to need a digital converter box.
Akai CFTD2083 20... | Answered on May 16, 2011
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Akai CFTD2083 20... | Answered on Oct 17, 2010
Try website like Remotes.com to buy an exact to the original or very close compatible to the original remote.
Akai CFTD2083 20... | Answered on Oct 12, 2010
No,try website like Remotes.com to buy an exact to the original remote.Ask the person given u that tv.Give u that secret codes.Not resetable tv to erase any secret codes.
Akai CFTD2083 20... | Answered on Jul 24, 2010
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Hope it works well...
Akai CFTD2083 20... | Answered on Jun 01, 2010
look on the back of tv for a 1800 number to call for help and if there is one call they should be able to help you also can search the net for akia manuel with your model.
Akai CFTD2083 20... | Answered on Jul 27, 2009
You will need to buy the exact remote for that model to turn the lock off.
Akai CFTD2083 20... | Answered on Jun 12, 2009
I think your Video Drum needs to be replaced since it's bad. You can get replacement Video Drums on the Internet.
Akai CFTD2083 20... | Answered on Feb 24, 2009
Akai CFTD2083 20 in. TV/VCR/DVD Combo Logo
Popular Tags
66 questions posted
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
thin white horizontal line across
  • Televison & Video
