20 Most Recent Hoover L2310 GUV Central System Vacuum Questions & Answers
I suspect the hoses are plugged with debris.
Hoover L2310 GUV... | Answered on Apr 21, 2017
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
Hoover L2310 GUV... | Answered on May 28, 2009
no one is exaust so one sucks one blows sucks is inside for vac . blows gets exsausted outside
Thank you for useing fixya please rate me
Hoover L2310 GUV... | Answered on Feb 12, 2009
There should be a manual/auto switch. If it is in the manual mode, then it will run all the time. Other then that you probably have a stuck relay. But this will have a years warranty on it, so you should be able to have it serviced under warranty.
Hoover L2310 GUV... | Answered on Mar 10, 2008
The bottom plate covers the brushroll, the top cover must be removed to gain access th where the belt goes around the motor shaft. There are catches on each side that must be flexed out to allow the top cover to come off.
Hoover Vacuums | Answered on May 20, 2018
Fixya does not sell Hoover filters.
Hoover Vacuums | Answered on May 06, 2018
Is your hose or tube blocked?
Hoover Vacuums | Answered on May 02, 2018
A belt melting usually means it is stretched out and so loose it is slipping on the brushroll or something is restricting the brushroll from turning freely.
Hoover L2310 GUV Central System Vacuum Logo
Popular Tags
10 questions posted
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
no suction air blowing out from tube
  • Vacuums
