20 Most Recent Akai PT5492S 54" Rear Projection Television Questions & Answers
These sets use what is called a "switch mode" power supply. In order for them to work there is a capacitor that "kick" starts the process. If that cap goes bad, the power supply will not start up. Also, there are other caps inside that maintain the oscillation required for the power supply to work. There are 2 options for you here.
1) Replace the entire power supply module.
2) Repair the existing one.
Sicne these types of power supplies are not the easies to diagnose or repair, I would suggest that you replace the power supply module. That should resolve the problem.
Please note that there are other causes of the reported problem, but hte power module becoming defective is the most common.
Dan
Akai PT5492S 54"... | Answered on Sep 18, 2018
SORRY but only you can decide when enough is enough to waste repairing the dinosaur and move on to a more dependable unit .
Akai PT5492S 54"... | Answered on Oct 08, 2017
Check out your audio board.
Akai PT5492S 54"... | Answered on Nov 18, 2015
Hello. The chirping probably indicates a shorted transistor or diode, and the burnt smell usually indicates a blown capacitor or a burnt resistor, or multiple damaged parts. I would have to see the TV to be of any further assistance. Sorry I couldn't be more helpful. Good luck.
Akai PT5492S 54"... | Answered on Oct 29, 2015
This could be one of many different issues. Main flaw with these units are as follows:
Blue picture tube leaks coolant onto neck board and mainboard causing problems.
Akai PT5492S 54"... | Answered on Jun 24, 2015
It's possible the mirror has dome dust on it from jostling during the move. W dried water spot will do it too. The front screen will come off by removing the screws on the bezel. Be extremely careful cleaning the mirror.Any scratch by a cleaning cloth (never use paper) will permanently ruin it.
Akai PT5492S 54"... | Answered on Nov 02, 2014
Try putting TV on Chan 3,4, 21, or 62.
Akai PT5492S 54"... | Answered on May 16, 2014
Hi Glenn,
Just change your region into SECAM / PAL / NTSC on your TV to change the color of it.
I hope my solution may help you.
Thanks for using Fixya...;-)
Akai PT5492S 54"... | Answered on May 06, 2014
If the distortion that you see can be described as somewhat of a 3-D picture, the problem is teh convergence circuit and this can be fixed easily. Also, if you can solder, you can fix this yourself. If you wish to do this, please update this and I'll provide you with some instructions.
Dan
Akai PT5492S 54"... | Answered on Sep 19, 2013
This usually is indicative of the EXTREMELY HIGH VOLTAGE anode connection somewhere between the flyback transformer and one or more of the crt picture tubes or the splitter. Being that this circuit has a running voltage potential of over 30,000 volts if you are not familiar with these YOU CAN BE KILLED messing with it!!! What happens is that there is a breakdown of insulation over time usually from dirt or other environmental contamination. Usually a good cleaning and replacing the HV anode wire that has failed. (hint) it will be the one that the "ticking noise" is coming from. The ticking noise is actually the high voltage arcing to the chassis/ground.
Be careful!!!!
Akai PT5492S 54"... | Answered on Sep 13, 2013
Tengo el mismo problema como lo areglaste?
Akai PT5492S 54"... | Answered on Oct 19, 2012
My fixing it directly to the cord
Akai PT5492S 54"... | Answered on Sep 15, 2012
might just be the fuse (a 1.5 inch glass tube inside the back panel by the power cord ,)
BE VERY CAREFULL IF YOU DECIDE TO CHECK IT!!!!!!!!!
make sure that THE TV IS UNPLUGED,
USE A RUBBER HANDLED FLATBLADE SCREWDRIVER TO POP THE FUSE OUT
DON'T TOUCH ANYTHING BUT THE FUSE ITSELF!!!
if its not that- its a transformer and not worth fixing
sorry but I'm taking NO RESPONSIBILITY if you zap yourself
i'm only telling you what I would do to check it without killing myself
Akai PT5492S 54"... | Answered on Aug 22, 2012
If it does not do it via the rear audio and video jacks (a DVD etc) problem may be a bad tuner or even a bad connection on the cable wire or fitting at rear of set--move the cables at connection points with set on to see if a reaction.
If not from DVD etc there is a way around this issue.
Akai PT5492S 54"... | Answered on Jun 13, 2012
A DUPLICATE of another question listed here--see my other answer--touch that it gets directly into your body and is toxic.
Akai PT5492S 54"... | Answered on Apr 28, 2012
Akai PT5492S 54" Rear Projection Television Logo
182 questions posted
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
gracias amigo fijate que ahora si
  • Televison & Video
