Troubleshooting & Support
Hot Topics:
- emachines t3104...
- d33007 vg31
- set screensaver...
- drivers pc...
- t3104
- drivers de...
- emachine t3104
- machine t3104...
- emachines t3104
- emachine w3644
- restore...
- drivers xp
- pci simple...
- te 8500
- bios setting...
- audio drivers...
- w5233
- video driver
- drivers de...
- restore...
- t3104 system...
- tower not power
- need driver...
- audio drivers
- hard drive
- power wont turn
- hardware
- ram memory...
- diagram...
- restore
- View All »
Problems & Solutions
Have an older emachines T3104.
If you know the manufacturer of sound chip, go to their web site and get the driver. You can look in the device manager to find the sound...
did a system restore on my computer but when it
go to device manager and re-install sound drivers
audio drivers
You should be able to use the Realtek AC97 codecs for your machine. You have a choice of standard AC97 (probably the one you're looking...
PC freezing up after memory upgrade
You can use a utility called CPU-Z to find the timing of the memory installed in the PC. Then check your memory documentation (I could find...
My slcdii file is missing, how do I retrieve it?
Its scl dll file not slc dii.1. Download, install and run DLLSuite, 2. Click Start Scan button to conduct a full scan for slc.dll as well as...
i plugged speakers into the
the problem with the you sound driver u have to install it
i CAN NOT FIND MY
Recommendation, just burn it now and get it over with. I have one of those worthless doorstops in the corner of my room.
Hi i recently installed windows
Ok, you need to install your audio driver which you can search here: http://support.gateway.com/us/en/emac/product/category.aspx You did...
how do i unlock my computer forgot password
follow the steps: -open the case. -there is a small battery on the mother board. -remove the battery for 15 seconds and replace...
I have a emachine T3104
I believe this is the motherboard of your pc. Check the manual here. On page 13 is the info you seek.
I show on monitor
This can be caused by any of the following: The video signal cable connectors have become dislodged either on the monitor or the PC. Check...
WANT TO TRANSFER MY EASY SHARE PHOTOS FROM COMP TO
You purchase normal CD DVD for writing photos, but writing mode is properly selected using your nero software or other writing software.
Lost sound--mute
Click Start > All Programs > Accessories > Entertainment > Volume Control Make sure None Of the Boxes are Checked Mute
cant find how to update my video driver
You'll have to go to the manufacturers website of your video card to download the latest drivers. If you provide me with your...
audio and video drivers
when you are in the device manager have the computer search for new hardware and see if the devices show up. As for the drivers the ones off...
Unsolved Problems
cd rom wont open
Press the button on the cdrom drive and nothing happens. Open up device manager and the computer does see the drive and...
e machines front panel wiring diagram e machines
e machines front panel wiring diagram e machines T3104
i have a emachines computer
i have a emachines computer model # T3104 and it says i have no sound or adio devices installed what do i do?
no driver audio for my
no driver audio for my emachine t3104 need help
Upload a manual for E-Machines (T3104) PC Desktop
Specifications
TopKey Features
Full Product Name:E-Machines (T3104) PC Desktop
Operating System:Microsoft Windows XP Home Edition
Processor:AMD Sempron 1.8 GHz
Installed Memory:256 MB (DDR SDRAM)
Recommended Use:Home Use
Chipset:VIA K8M800
Processor
Processor Type:AMD Sempron
Processor Speed:1.8 GHz
Processor Manufacturer:AMD
Max Processors Qty.:1
Installed Qty:1
Motherboard
Bus Speed:1600 MHz
Video Output Interface:AGP 8x
Memory
RAM Technology:DDR SDRAM
Installed RAM:256 MB
Installed Cache Memory:256 KB
Max Supported RAM:2 GB
Supported RAM Speeds:400 MHz
Technical Features
Expansion Slots:PCI x 3
Expansion Slots:AGP x8 x 1
Integrated Input/Output Ports:Serial Port x 1
Integrated Input/Output Ports:PS/2 Mouse x 1
Integrated Input/Output Ports:PS/2 Keyboard x 1
Integrated Input/Output Ports:Parallel Port (ECP/EPP/SPP) x 1
Integrated Input/Output Ports:RJ45 Lan Port x 1
Integrated Input/Output Ports:USB 2.0 x 5
Other Features:Media Card Reader
Memory Card Slots:MultiMediaCard
Memory Card Slots:Micro Drive Memory Stick
Hard Drive
Hard Drive Capacity:100 GB
Hard Drive Rotation Speed:7,200 RPM
CD / DVD
Optical Drive Type:CD-RW/DVD-ROM (Combo)
Optical Drive Read Speed:16x (DVD)
Optical Drive Read Speed:48x (CD)
Optical Drive Write Speed:48x (CD-R)
Optical Drive ReWrite Speed:32x (CD-RW)
Audio / Video
Audio Output Type:Sound Card
Audio Output Type:Line Out
Video Out Ports:15 Pin D-Sub VGA port x 1
Integrated Audio:AC'97 Audio Codec
Modem
Modem Type:Fax / Modem
Networking
Networking Type:Integrated 10/100 Network Card
Dimensions
Depth:16 in.
Height:14.25 in.
Width:7.25 in.
Weight:22.5 lb.
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
5,101
5,101 people have viewed this product
- 22 people asked about this product.
- 16 people found solutions for this product.
- 3 people have added this product.
Automatically...
How to Keep...
Computer Repair...
