20 Most Recent AMD Athlon , 750 MHz Processor Questions & Answers
Hangs at PCI device listing
Go to the bios settings and reset it to Optimize Default and reboot the system after saving the settings. To go to the settings, follow the onscreen instructions of your manufacturer's direction (maybe Delete or F2 or F1). You also need to scan your system with an updated antivirus and make sure that you haven't installed two antivirus. If possible restore your system to the previous date when it was working fine. do let me know again if you can't follow all these. good luck..
5/13/2010 6:50:13 PM • AMD Athlon , 750... • Answered on May 13, 2010
Can't boot 2nd OS system from partitioned HD.
go to add and remove software, deleted the last update from Microsoft. it should put you back to dual boot. try to install the update manually one at a time. find the one that prevent you from dual boot and discard the update. you should be OK w/o ceratin updates.
6/4/2009 4:03:46 PM • AMD Athlon , 750... • Answered on Jun 04, 2009
Dual Booting
Yo u cant dual boot without restarting the machine unless you use virtualization technology ie virtual pc or vm ware
Regards Al
5/26/2009 6:52:04 PM • AMD Athlon , 750... • Answered on May 26, 2009
PCI cards don't function
as been have ssen in picture and specs of your mainboard you have a integratd vga vard and a agp slot. so solution may be this
with old integrated vga open bios program go to disply and choose pci input first. this enable you to boot from pci slot with a new vga save setting switch of computer put on new pci vga and try.
if no option to activate pci init first , sorry you can not boot any vga from pci , but only from agp slot.
4/7/2009 6:41:40 PM • AMD Athlon , 750... • Answered on Apr 07, 2009
Computer hangs when PCI Device Listing comes up
Make sure they are put back in the exact same slots that they came from. If this doesn't work, I can't help you.
11/9/2008 9:59:39 PM • AMD Athlon , 750... • Answered on Nov 09, 2008
How can I get User manual for AMD Desktop Motherboard AM2, DA061L-3D, 48.3BU01.01M, 09178-1M U
I would try the AMD web site. If still available, you will find one there.
6/29/2021 6:50:31 AM • AMD Computers &... • Answered on Jun 29, 2021
I just installed a motherboard because my video went out and the Onboard as well as the video card would not connect. I installed a power supply, new memory, new cpu, new hard drive, new video card and when all that failed still I installed a new motherboard. Still not connecting to the monitor. What am I missing? Here are my specifics. Upgrades Motherboard Foxconn A74ML-K AM2+ AM3 740G Motherboard AMD DDR2 MicroATX SATA PCIe x16 Phenom Video Card Dell ATI Radeon HD 4350 512MB DDR2 PCIe VGA DVI HDMI Graphics Video Card 0P002P Power Supply Apevia BT550W Beast 550W ATX Gaming Power Supply, Supports Dual/Quad Core CPUs Hard Drive Seagate BarraCuda 2TB Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache 3.5-Inch Dvd rom LG Internal 24x Super Multi with M-DISC Support DVD Burner  USB Card FebSmart PCIE 4-Ports Super Fast 5Gbps USB 3.0 Wifi adapter USB WiFi Adapter – 1200M WiFi Dongle High Speed 802.11ac 5dBi Dual Band 2.4/5GHz  Memory LEVEN DDR2 4GB (2GB×2) 800MHz PC6400 Unbuffered Non-ECC UDIMM 240 Pin CPU AMD Phenom II X3 710 2.6Ghz Processor Cpu Cooler Cooler Master CM12V Ultra Silent 8032 Fan Dimensions: 80x80x32 MM Voltage: DC 12V Speed: 2000 RPM Air Flow: 32.5 CFM Noise: 18 dBA Feature: Very Quiet & Long Life Span, Speed Sensor (Tach) Termination: 3-Pin / 3-Wire / 7.5-Inch After my new build would not boot properly I thought it was a video problem and was all ready to rma it. I specifically checked the manual for proper placement of the cmos jumper before I assembled it after reading of other peoples problems with the jumper left in the "clear" position. That's what I get for reading the manual. The jumper was actually placed correctly from the factory. The manual was wrong. -2 eggs for poor documentation and the headaches to find and fix the problem.
Perhaps the monitor is faulty? Did you check that with a device known to work. Listen to Larry though, he is the Hardware Guru here at Fixya.
4/8/2021 11:34:28 PM • AMD Computers &... • Answered on Apr 08, 2021
I have a windows 7 desktop 64bit, amd sempron LE-1200, that reads usb2.0. how do i get it to read a usb3.0 flashdrive without corrupting files when moved on it
USB 2 and 3 are the data speed capability of the interface it is possible to connect a USB3 flashdrive into a usb2 socket all that will happen is the files will transfer slower than on a usb3 socket. Hope this was helpful.
5/14/2020 11:25:53 PM • AMD Computers &... • Answered on May 14, 2020
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
3/20/2019 5:10:23 PM • AMD Computers &... • Answered on Mar 20, 2019
I have an AMD Athlon 64 X2 Dual Core processor running on Windows 7 32 bit. Can I install Windows 7 64 bit oS on this system?
yes but fresh install will be needed.back up important docs first
12/15/2018 8:53:13 PM • AMD Computers &... • Answered on Dec 15, 2018
yes you can. Win 7 win8 win 8.1 are no supported by Microsoft, only win 10.
12/15/2018 8:29:15 PM • AMD Computers &... • Answered on Dec 15, 2018
Hi i just joined and im so clueless what im goin to do amd where and how to statt Please i need your help someone pls! Thank you
on the ask a question page , type in the make , model year, type of equipment and the problem that you have and post it
4/30/2018 5:02:16 AM • AMD Computers &... • Answered on Apr 30, 2018
AMD Athlon , 750 MHz Processor Logo
5 questions posted
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AMD Computers & Internet
Most Popular Question
hangs pci device listing
  • Computers & Internet
