Troubleshooting & Support
Hot Topics:
Problems & Solutions
My W3410 eMachine desktop won't Boot at...
Sounds like a harddisk failure unfortunately. You might want to boot your original OS disc and perform a repair (non-destructive), this...
why wont my emachine desktop burn data onto a dvd
First check whether you have a DVD writer or not.1)If you drive is a DVD writer a DVD-RW will be written on top of the drive otherwise it is...
the power button came unplugged from the tower i
EVerything should be color coded. The big black cord for power has to be plugged in last. all other plugs can be plugged only in one spot....
can't get computer hooked up correctly to...
Assuming you are on a network, you should be able to search for the printer and connect to it by simply browsing the server it is installed...
hard reset on the emaachines el1200 manually
Start your computer up in Safe Mode and see if you can get to your recovery management that way. when you first boot up look for the F-8 key...
On working on my mother's emachine W3410. Her
test the ram and the cpu, if its not one of those, then it IS the motherboard.
cant find my restoration disks
Contact the copmapny to obtain another one. http://www.emachines.com/support/product...
how do i reset to factory settings
Contact the company to obtain another one. http://www.emachines.com/support/product...
lan problem
Hi ramlance, click the link I have posted below. This is the download page for your E-machine W3410 PC desktop....
emachines t5212 overheat message then shuts down
Three causes of ovheating:1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed...
where do I plug in a modem in an e-tower 466?...
I had one of these models and the phone modem is built in and not replaceable---I retired mine as it was just too slow at doing things and...
I restored T5048, but now it shuts down and...
Shuts down and restarts the boot process automatically continuously. Try turning it off, then hit the power button and immediately...
The 945GCT-M3 motherboard wireing diagram for the...
power connecter has totally 9 pins on the board but actually we have to use only 8 pins please refer the attached image if you have further...
computer system locked and dont remember password
I hope you forgot the password for your Operating System Log On. If you forgot your boot password of your bios, then this may not be as...
Unsolved Problems
where can I download the
where can I download the SM Bus Driver for a emachines w3410
can i use sata 300
can i use sata 300 hard drive with an e machine w3410
I need to install a serial port on a El1200-06w so
I need to install a serial port on a El1200-06w so it will read information from a medical scanner. The port coming from...
how do i set up
how do i set up up my emachine.it powered off when i was setting up because of low charge.now when i try to get on it it...
I have a e machine w3410 with no video bought a
I have a e machine w3410 with no video bought a new power supply 700 watts bfg fatality and still no signal replaced lil...
Can't get computer hooked up correctly to Epson printer just moved and have a different server formally was windstream...
Upload a manual for E-Machines W3410 PC Desktop
Specifications
TopKey Features
Full Product Name:E-Machines W3410 PC Desktop
Operating System:Microsoft Windows XP Home Edition
Form Factor:Tower
Processor:AMD Athlon 64 2.2 GHz
Installed Memory:512 MB (DDR SDRAM)
Recommended Use:Home Use
Chipset:ATI RS480
Display:15 in. Flat Panel LCD
Processor
Processor Type:AMD Athlon 64
Processor Speed:2.2 GHz
Processor Manufacturer:AMD
Processor Upgradability:Upgradable
Max Processors Qty.:1
Installed Qty:1
Socket Type:Socket 754
Display
Display Type:Flat Panel LCD
Motherboard
Bus Speed:1600 MHz
Video Output Interface:PCI Express
Memory
RAM Technology:DDR SDRAM
Installed RAM:512 MB
Installed Cache Memory:512 KB
Max Supported RAM:2 GB
Supported RAM Speeds:400 MHz
Number of Memory Slots:2 x DIMMs
Technical Features
Expansion Slots:PCI x 3
Expansion Slots:PCI Express x16 x 1
Integrated Input/Output Ports:Serial Port x 1
Integrated Input/Output Ports:PS/2 Mouse x 1
Integrated Input/Output Ports:PS/2 Keyboard x 1
Integrated Input/Output Ports:Parallel Port (ECP/EPP/SPP) x 1
Integrated Input/Output Ports:RJ45 Lan Port x 1
Integrated Input/Output Ports:RJ11 Phone Jack x 1 (Input)
Integrated Input/Output Ports:USB 2.0 x 7
Expansion Bays:2 x 3.5" (External Access)
Expansion Bays:2 x 5.25" (External Access)
Expansion Bays:1 x 3.5" (Internal Access)
Other Features:Media Card Reader
Memory Card Slots:MultiMediaCard
Memory Card Slots:Micro Drive Memory Stick
Hard Drive
Controller Type:EIDE
Hard Drive Capacity:100 GB
Hard Drive Interface:EIDE
Hard Drive Rotation Speed:7,200 RPM
CD / DVD
Optical Drive Type:DVD??RW Dual Layer
Audio / Video
Audio Output Type:Sound Card
Audio Output Type:Line Out
Graphic Processor:ATI Radeon X200
Audio Input:Microphone Jack
Audio Input:1 x Line In
Video Out Ports:15 Pin D-Sub VGA port x 1
Integrated Audio:AC'97 Audio Codec
Modem
Modem Type:Fax / Modem
Networking
Data Link Protocol:Ethernet
Data Link Protocol:Fast Ethernet
Networking Type:Integrated 10/100 Network Card
Dimensions
Depth:16 in.
Height:14.25 in.
Width:7.25 in.
Weight:22.5 lb.
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
1,766
1,766 people have viewed this product
- 20 people asked about this product.
- 10 people found solutions for this product.
- 2 people have added this product.
Automatically...
How to Keep...
Computer Repair...
