20 Most Recent Miele Optima G2470SCVi Built-in Dishwasher Questions & Answers
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Miele Optima... | Answered on May 31, 2015
What is the problem?
Miele Optima... | Answered on Apr 06, 2013
Please check the INLET water pressure, remove the inlet and check. Now if there is pressure make sure that when the power is pressed there is a pre wash cycle to start the machine. If not there is fault in the program controller , please check the door switch and the panel board.
Miele Optima... | Answered on Jan 02, 2013
Miele Optima G2470SCVi Built-in Dishwasher Logo
57 questions posted
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Miele Dishwashers
  • Miele Dishwashers
Most Popular Question
fault code f70 drain pump keeps
  • Dishwashers
