20 Most Recent
Elo TTX 9154 15 Inch LCD BLACK W/ RESISTIVE SERIAL Interface Monitor Questions & Answers
Proper Monitor Cable needed and PS Cable!
Hi Maestro_mark,
These cables can be bought at a store where they deal in PC's and any such high end electronics.
No specifications needed. Just tell the dealer the model number of your monitor and ask for the required cables. If he has a manual the he should refer it if he too is doubtful about anything.
That's all.
My 15" LCD monitor TTX went to sleep mode and never return back
mike_garzan, Your monitor will need some work done on it!! Do you know the "flashlight trick" that every owner of an LCD monitor with "cold cathode-fluorescent-lamps" should know how to do when the BLACK screen of death makes it presence known? Do this test first! It is a very easy test to do. 1. With a KNOWN GOOD pc fully booted to the WIN-desktop showing on a GOOD Monitor have a friend tap the CTRL key on the keyboard every 30 seconds or move the mouse to ensure that the pc won't go into sleep mode. 2. Power off the good monitor and disconnect it from the pc. Now reconnect the TTX9151 to the pc and wall outlet power. 3. Then and only then turn on the monitor and make note of what happens. Did you see or not see the WIN-desktop appear?
4. Now for the flashlight test. Even though the LCD panel appears BLACK, shine a bright flashlight about 1" from the screen's lower left corner and make note if you can see the Windows START icon even though the screen appears to be BLACK. 5. Turn off TTX9151 or yank the plug from wall outlet, and disconnect from pc. TEST IS DONE. Reconnect good monitor to pc to get back online. The test was to evaluate the current status of the "switch-mode-power-supply" and the CCFL inverter circuit DC source. If you could SEE something on the BLACK screen then you know that half of the SMPS is working and sourcing voltage (+5 or +3.3v) to power the vga/lcd interface board! It also means that the SMPS is not in FULL SHUTDOWN mode and only has a problem sourcing voltage(+12v to +18v) to the CCFL inverter circuit which generates 800v to 1200v ac to light-up the CCFL's that are hung across the rear of your LCD panel to produce the WHITE LIGHT needed to see what is on the screen. Now, if you didn't see the WIN-desktop, then the SMPS is probably in complete SHUTDOWN mode trying to save itself from a CATASTROPHIC, NONRECOVERABLE failure! (eg. smoke and fire) Put the TTX9151 in a safe place and get back to me with results of the TEST. lmistyrel and on aim.com or do a comment to your original post above on fixya and I'll give you advice as to what you need to do about getting it repaired or other actions/options you as a consumer/user of LCD displays have open to you. Bye for now. 12fixlouie
I can not hear any sound through the speakers of
The Elo ET1527L Monitor has stereo speakers. Within the OSD (On Screen Display) you can control several properties of the monitor like; brightness, contrast, positioning, color, and SOUND. See the buttons on the right side.
I recommend setting the sound to 100%. The speakers are small and weak. They are pointed to the rear, I assume for customers to hear.
The buttons do have a lock-out feature too. If they don't respond, while on, hold down the top two buttons and the screen should display Lock / Unlock. Wait until you see the one you want and then release. The power button lock out works the same way, holding top and 3rd button to lock/unlock.
The device drivers give you an option to use internal (monitor beeps) and external (PC port) sound sources.
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
