FixYa.com
Draytek Vigor 2600V Router
All Products > Draytek > Routers
Problems with Draytek Vigor 2600V Router?
Search inside Draytek Vigor 2600V Router Knowledgebase
Troubleshooting and Support
Solved Problems for Draytek Vigor 2600V Router RSS Feed Post a New Problem
Are NAT routers good firewalls ?
1 Solution
What ports do I need to open to permit VPN...
What ports do I need to open to permit VPN traffic?
1 Solution
configure DMZ Host
How do I configure the DMZ Host on my Router?
Post a Solution
where should I place my router?
I'm trying to get the best range possible, where should I place my router?
1 Solution
linksys wrt54gs cant connect..
Hello, I have this problem: I cant connect to my linksys wrt54gs, i cant ping to default ip 192.168.1.1,or connect...
2 Solutions
Quick repetitive disconnects
I've my router setup properly, but I encounter quick repetitiv e disconnects from time to time.Usually at disconnect,...
1 Solution
not working ,just red light
hi, my speedstream5260 is not working i got just solid red light in all the indicators could you please help nali
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
ConnectivityWired
FunctionalitiesDHCP Server · Firewall · Voice over IP Gateway (VoIP) · VPN Pass-Thru
Interfaces
Built-In4-port Built-In Switch
LAN Interfaces10/100 Base-T
WAN Interfaces1 x 10/100 Base-T
Additional Interfaces1 x USB · 2 x RJ-11 Phoneline for VoIP
Standards and Protocols
Management ProtocolSNMP · Telnet
Routing ProtocolsStatic Routing · RIP Version 2
ProtocolsTCP · DHCP · PPP · IPoA · ICMP · AAL5 · UDP
Firewall / VPN
VPN EncryptionDES · MD5 · SHA-1 · 3DES
Firewall FeaturesStateful Packet Inspection (SPI) · ActiveX / Script Blocking · Port Filtering · DoS Prevention · Content Filtering · Cookies Blocking
VPN ProtocolsPPTP Pass-Thru · IPSec Pass-Thru · L2TP Pass-Thru
Wireless
Wireless SecurityAES
Modem
Modem Max Downstream8 MBps
Modem Max Upstream1 Mbps
DSL StandardsADSL Lite (G.Lite ITU G.992.2) · ADSL Full Rate (G.DMT ITU G.992.1)
Other Features
Additional FeaturesUPnP Certified
Dimensions
Depth8.66 in.
Height1.44 in.
Width6.3 in.
Draytek Contact Information
Main support number+ 886 3 5972727
Email supportsupport@draytek.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
