20 Most Recent
Hyundai ImageQuest B70A 17" LCD Monitor Questions & Answers
I have a hyundai monitor B70A and it is not
Assume you tested this on another computer to see if there was a problem with the graphics input, check the vga cable and ensure it is secure at the graphics card end and the monitor connector. Check the sockets of both these to make sure there is no damage.
Once you eliminate the obvious possibilities, you are left with the fault being at the monitor end. Typically this could be one of the board power capacitors that is not allowing the charge to power up the screen. The amber light indicates that power is reaching the monitor but the charge necessary to light the screen is not getting through.
Refer this to a competent TV repairman for checking and repair (if economical)
6/23/2011 10:19:07 PM •
Hyundai...
Answered
on Jun 23, 2011
Can i but a power
I believe that this site (fixya.com) is just a help site. I have found that in the past ten years, every TV set and computer as wll as several other devices have used the same type of power cords. If you have an older computer around, then the cord will fit most TV sets. You could drop by a computer fixet it store and they will either give you or sell cheap, (<5bucks) an old power cord. You could also look at the electronic store and find a usable cord that you can subs5titute.
5/17/2011 6:38:48 PM •
Hyundai...
Answered
on May 17, 2011
When i shut down my
Possible errors in the OS and it will be good to use the restore action so as to set the PC to an earlier set date. make sure your PC is virus free. If you have the same issues then the OS must be reinstalled, the drivers installed after a good anti-virus is also installed.
4/1/2011 6:17:13 AM •
Hyundai...
Answered
on Apr 01, 2011
Brand of monitor is the following: HYUNDAI-
First of all, I want to thank debbcake for providing the name / brand / model # etc twice, as well as listing the technical info for the B70A. Verifying the units true identity is first priority, and this info, although redundant and repetitive, was immensely helpful in preventing any confusion and was crucial in the final determination process, and she should definitely be commended
for taking the time to provide this information.
However, I feel obligated to point out that debbcake, although obviously quite skilled at copy and paste,neglected to also include the problem she was (is) having with the B70A .
I sincerely hope she will rectify this situation asap. as I am genuinely looking forward to assisting her with whatever problems shes having.
Respectfully,
D.
10/15/2010 3:59:59 PM •
Hyundai...
Answered
on Oct 15, 2010
My B70A Hyundai will not power on. The green or
This monitor is plug and play but the driver (or lack of) is not the problem.
Its either your the power supply or the monitor itself has an issue with its
internal power distribution circuitry. First make sure your power supply is
operational. The original 120V AC to 12V DC 3.3 A power supply for the
B70A had a green LED on the brick itself. You will find it on the top right
corner of the brick, on the end where the DC cord comes out (opposite
end from the AC input) If you have the AC cord plugged in the wall, the
LED should be lit. If it isn't, the brick is no good, and should be replaced.
Any 12 VDC adapter with an amperage rating of at least 1A but no greater
than 3.3 A having the same size tip (with correct polarity) should work.
If you have confirmed that the adapter IS functional and the monitor LED's
still remain off, the internal power distribution circuitry of the monitor is
damaged, probably caused by burst or leaking capacitors.
10/15/2010 1:12:22 PM •
Hyundai...
Answered
on Oct 15, 2010
Why won't my Hyundai B70A moniter stop flickering?
It may have problem with power supply due to bad caps, or in the backlight inverter circuits, please read below and look at my pictures so you will have some ideas what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
5/8/2010 11:11:38 PM •
Hyundai...
Answered
on May 08, 2010
Trying to find a website that can help me with my
You are at the right place here.
First we need to find out if the porblem is in the monitor or in the PC sound card.
Try feeding the monitor with sound output of MP3 player or iPOD. If you do get sound, then you will need to look at the PC sound if the correct driver is installed properly.
If you do not get the sound from the monitor, then we will need to open it up and do some electronics troubleshooting down to components level which I am not sure if you will want to get that far or not.
So please post back after verifying with MP3 player and let us know what happen.
4/26/2010 2:09:46 AM •
Hyundai...
Answered
on Apr 26, 2010
How do I reset the screen? The screen shows
You get that message because the PC video out put is too high for the monitor to support, you need to set the PC video output to native resolution:1280 x 1024 @60Hz.
4/2/2010 3:29:32 PM •
Hyundai...
Answered
on Apr 02, 2010
My Hyundai B70A Flat screen monitor all of a
replace the signal cable user can also replace it that cable is detachable and attachable if persists then there is a dry solder inside the monitor. one possibility is that vga connector of motherboard may loose or faulty.resolder the connector
3/22/2010 1:41:20 AM •
Hyundai...
Answered
on Mar 22, 2010
Voltage and polarity for Hyundai B70A
Your monitor needs a 12volt 5amp power supply with + 5,5mm tip. Most universal power supplies will not supply enough amps to power an LCD monitor. If you need an adapter we do have them in stock at:
http://www.ccl-la.com/parts_lcd.htm I hope this helps, if so please rate this solution.
Buddy
Corporate Computer
www.ccl-la.com
1/16/2010 3:08:18 PM •
Hyundai...
Answered
on Jan 16, 2010
