20 Most Recent iiyama ProLite E481S-B 19" LCD Monitor Questions & Answers
I#m just facing the same problem with my iiyama monitor. How to open the cover? Did you find out in the meantime? I suppose there are hidden snap-in connections behind the front cover.
iiyama ProLite... | Answered on Apr 01, 2015
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
You should see the picture again.
iiyama ProLite... | Answered on Apr 25, 2011
Maybe this link has the answer that you need! I have the same problem with a LCD monitor
iiyama ProLite... | Answered on Mar 20, 2011
It mau have bad DC due to bad DC filter caps. Look for leaking/bulging top caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
iiyama ProLite... | Answered on Oct 03, 2010
hi if you have an xbox elite the you can do it via hdmi cable, but if you have the normal xbox360 then its just the vga plug ime affraid hope this helps
iiyama ProLite... | Answered on Feb 22, 2010
Was there an installation disc that came with it in the package? Some monitors require software to be used. If you don't have the installation disc, you will most likely find the necessary software on the manufacturer's support site: ProLite Support Driver Download Site.
If the monitor software doesn't solve the problem, try using a different DVI cable. More often than not, these types of problems can be traced back to a faulty cable or port. If the DVI port on the monitor is bad, you will have to use the VGA port as you are now or replace the monitor.
If the DVI port on the video card is bad, you will need to replace it. A good way to test this is if you have another monitor with an available DVI port you can connect to the video card.
Hope this helps! Good luck!
iiyama ProLite... | Answered on Aug 11, 2009
you might just need to touch the resolution or else check if the monitor has right settings from its inbuilt menu.
iiyama ProLite... | Answered on Mar 17, 2009
If you're talking about a CRT that is going on "The Blink", yes this is where the name comes from. And this is becoming more and more of a problem you do indeed need a new monitor.
Three good places to shop online is :
Be certain what ever you buy is compatible with your current video display adapter. If your adapter has a VGA and a DVI socket than you can get either in a flat panel which is to say 60Watts vs 180 Watts in power consumption. The larger the flat panel the more power it consumes. More often than not, a 17 or 19" flat panel is more than sufficient. If you actually plan on sitting at your PC and watching movies go wider. If you are a hard core gamer go wider. Otherwise, a 17 or 19" monitor should serve you well.
iiyama ProLite... | Answered on Jul 07, 2008
Get a cable two male ends. Look for the female end on your screen. Put one male end into the port on on your screen and the other end into the port "AUDIO ONE" on your computer.
Try this it should work. The Multi-PIN cable is only for VIDEO, you need another cable for AUDIO.
iiyama ProLite... | Answered on Feb 03, 2008
If you are configuring the menu option displayed on the monitor itself, there is no control clicking any options with the mouse cursor. You have to adjust the brightness settings touching the buttons on the monitor it self.
iiyama Computers... | Answered on Sep 24, 2016
iiyama ProLite E481S-B 19" LCD Monitor Logo
19 questions posted
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • iiyama Computers & Internet
Most Popular Question
fails power up until after about 10
  • Computers & Internet
