20 Most Recent
Jet Tech Systems X-35C Dishwasher Questions & Answers
Water will not shut off after starting
If water keeps running even if the unit is unplugged than the water solenoid valve has become defective.
if the water stops when power is off than there is a problem with either the timer or the fill switch. My bet is on the timer.
Always be careful when opening the top cover. you will be exposing wires. power must be turned off at the breaker or the unit unplugged.
Ready light does not come on and unit continues to heat after cycle complete. Rinse temp stays at 205 F.
Ready light is there to tell you the thermostats have cycled off, rinse temp first and then wash temp after. if the wash temperature is low (below 160F) then we need to look at either the thermostat for wash or the heather is bad. if bot the temperatures are ok then it is just the light that is bad. If the rinse temperature shows 205F on analogue thermometer, a secondary reading is necessary with an external thermometer on the booster it self. These analogs thermometers are not so accurate.
Plug getting hot
a plug can be warm. if it is hot to the touch, stop using it and have the machine checked and the receptacle check by a qualified technician.
The unit is overflowing and will not drain
for models equipped with a drain pump;
verify that the pump is not clogged. if it hums during the fill cycle or rinse cycle then something is lodged inside. If it doesn't then it needs to be replaced.
for models without the drain pump;
something is interfering with the water flow. when the stand pipe is removed, the tank should empty in about one minute.
Tech manual
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank.
Search by part number or description
No heat from F-14
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
We have a model F-18
www.jet-tech.com/products/F-18DP/f18_tech_manual.pdf
Copy and paste that link into your internet address bar or type it in.
That is your manual
Drain pipe broken
If this is a common problem then ring the manufacturer, if not you will need to have it replaced.
DIO3T131FEUK Integrated dishwasher has power but won't switch on
Check Power Supply:
First, ensure that the dishwasher is properly plugged into an outlet. Sometimes vibrations or nearby appliances can cause it to come unplugged.
If it's plugged in, test the outlet by connecting a small appliance (like a toaster or blender) to see if it turns on. If it does, move on to the next step.
Check Circuit Breaker:
Verify if a circuit breaker has tripped. Go to your circuit breaker box and look for any tripped breakers.
If you find one, flip it to the "off" position and then back to the "on" position.
Test the dishwasher again to see if it powers on.
Child Lock or Delayed Start:
Some dishwashers have a child-lock feature that prevents accidental starts or changes to the wash cycle.
Check your owner's manual for instructions on disabling the child lock or delayed-start features.
Ensure that the dishwasher door is securely latched.
Reset the Dishwasher:
If the dishwasher has power but won't start, it might be stuck between cycles.
Allow any drain cycle to run (if applicable), wait for 60 to 90 seconds, and then press the start button once.
Unplug the dishwasher for a minute or two, then plug it back in. This can help reset the machine.
Refer to the owner's manual for any specific reset procedures.
If none of these steps resolve the issue, consider reaching out to professional repair services or the manufacturer for further assistance.
4/21/2024 2:44:15 PM •
Dishwashers
Answered
3 days ago
Karcher Puzzi 100 Spray pressure low
troubleshoot the issue:
Spray Nozzle Blockage: Ensure that the spray nozzle is clear and not blocked. Sometimes debris or buildup can obstruct the nozzle, affecting the spray performance.
Pump Coil and Circuit Board: The pump coil could be damaged or broken. If it's faulty, the pump won't spray at all. You can check continuity through the coil and verify that the switch is supplying power to the circuit board and, in turn, to the pump. Dry solder joints or a failed smoothing capacitor on the circuit board can also cause issues. Pumps are relatively simple solenoid plunger types, and replacements are available for around £40-£50. If you're not comfortable testing at mains voltages, seek professional assistance.
Calcium Buildup and Blockages: Some pumps can be dismantled, allowing you to remove any calcium buildup or blockages. Gently tapping or shaking the pump might get it going. Recirculating a descaler can also help clear buildup without disassembly.
Pump Replacement: If the pump is indeed faulty, consider replacing it with a new one. It's advisable to change the circuit board (PCB) as well. If you're unsure about electrical testing, consult an expert.
Remember to follow safety precautions when dealing with electrical components. If you're not experienced, seek professional help to avoid any risks. Good luck with resolving the issue!
For reference, the Karcher Puzzi 100 is designed for gentle and effective cleaning of small to medium surfaces, especially carpets and upholstery2. Its spray pressure is around 1 bar, and the spray rate is approximately 0.26 gallons per minute. If you need further assistance, consider referring to the Karcher Puzzi 100 user manual.
4/20/2024 10:55:08 PM •
Dishwashers
Answered
on Apr 20, 2024
Can't get dishwasher out from underneath the counter
Question edited to move it from Computers to Dishwashers.
Is there by any chance a floor tile 4" out from the dishwasher front? If so, try lifting the front with a crowbar or long screwdriver.
Did you disconnect, inlet hose, drain and power? They may have been installed tight, or clipped.
4/19/2024 6:24:59 PM •
Dishwashers
Answered
on Apr 19, 2024
HOW TO REPAIR A HOLE IN MY DISHWASHER
It depends upon the material you are trying to repair but Araldite or any good quality two part epoxy will suffice to fill the hole.
Ensure the area is dry and clean then build up the repair . Larger holes will require multi additions of epoxy.
4/15/2024 10:01:23 PM •
Dishwashers
Answered
on Apr 15, 2024
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
These error messages both point to a sensor problem.
Error 12.1
This error is related to the boiler temperature sensor. Consider the following:
Look for a short circuit in the sensor. Inspect the cables and plugs for any issues.
Ensure the sensor is correctly connected.If needed, replace the boiler temperature sensor.
Error 22.2:
This error pertains to the tank temperature sensor. Possible causes include:
Short circuit in the sensor.
Cable failure or plug failure.
Sensor not properly connected.
You may need to check the sensor wiring, connections, and replace the temperature sensor if necessary.
4/3/2024 6:11:13 PM •
Dishwashers
Answered
on Apr 03, 2024
