Mitsubishi WD-62827 62 in. HDTV Television
Problems with Mitsubishi WD-62827 62 in. HDTV Television?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD-62827 62 in. HDTV...
Troubleshooting and Support
Solved Problems for Mitsubishi WD-62827 62 in. HDTV Television RSS Feed
View More Results for Mitsubishi WD-62827 62 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD-62827 62 in. HDTV Television RSS Feed
Answer
i have a mitsu dlp wd-62827 tv which has just begun to make a humming noise after an hour of... (More)
Answer
This just happened to me a few weeks ago June 5th, the warranty on my TV expired on June 18th, 2009.... (More)
Answer
I have a plastic screen covering my tv and want to know how to remove it. When I purchased it, I was... (More)
Answer
Second posting. My TV works fine if I unplug it for a couple hours or just leave it turned off for... (More)
Find a Manual
Mitsubishi WD-62827 62 in. HDTV Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi WD-62827 62 in. HDTV Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.... written by toddg
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WD-62827 62 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi WD-62827 62 in. HDTV Television
Key Features
Screen Size
62 inch
Digital TV Standard
HDTV - HDTV receiver is integrated. · HDTV
Projector Technology
DLP
Display Resolution
1920 x 1080 pixels
Combo Features
Playable File Formats
JPEG · WMA · MP3
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Image Quality
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Stereo
Surround Sound Type
Dolby Digital / AC3
Technical Features
Picture in Picture
With PIP
Connectors
Rear Input Connectors
S-Video x 2 · Composite x 2 · Audio (RCA) x 4 · 1 x RS-232C
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1 · Firewire (IEEE 1394) x 1
Screen Text
Closed Caption on Mute
Without Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
20.3 in.
Height
40.5 in.
Weight
146 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
