Everything else works. DVD, DVD-A and SACD all work but it will not play a Redbook CD. I have...
(More)
Everything else works. DVD, DVD-A and SACD all work but it will not play a Redbook CD. I have reset the player and nothing changes. Denon estimates a $200 fix plus shipping from and to Alaska. Can anyone think of something else to do?
i Hi, I need your help with my DVD player DVD-5900, it came with 2 CD Firmware updates, I have put...
(More)
i Hi, I need your help with my DVD player DVD-5900, it came with 2 CD Firmware updates, I have put the CD firmware CD1, and everything went fine , but, when I put the CD2 the DVD STOPPED OPERATING. Now the CD is stuck inside the box. The display only show ?DVD-5900? and nothing happens. None of the front panel buttons are functional. The machine seems to be jammed!.. What can I do ?, Is there an repair procedure I can do? How can I put it back into working condition? Please help. Regards, Christian
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
HDCD · CD-RW · CD-R · CD (Audio) · DVD Audio · DVD-RW · DVD Video · DVD-R · SACD
Playable File Formats
MP3
Video
TV Resolutions
480p (525p) · 720p (750p) · 1080i (1125i)
Picture Control
Zoom
Video Output System
NTSC · PAL
Video DAC
12 bit / 216 MHz
Video Noise Reduction
Block Noise Reduction · Mosquito Noise Reduction
Audio
Surround Sound
DTS (Digital out only) · Dolby Digital (Digital out only) · Virtual Surround
Audio DAC
24 bit / 192 kHz
Dynamic Range
110 dB (DVD)
Audio S/N Ratio
120 dB
Connections
Outputs
Composite x 2, S-Video x 2, Component x 2, DVI with HDCP x 1, Analog Audio x 2, Analog Surround x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1, iLINK (Audio Only)
