FixYa.com
NEC-Mitsubishi AccuSync LCD92XM  19" LCD Monitor
All Products > NEC-Mitsubishi > Monitors
Problems with NEC-Mitsubishi AccuSync LCD92XM 19" LCD Monitor?
Search inside NEC-Mitsubishi AccuSync LCD92XM 19" LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for NEC-Mitsubishi AccuSync LCD92XM  19" LCD Monitor RSS Feed Post a New Problem
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
How to Adjust the Number of Colors...
How to Adjust the Number of Colors Displayed on a Monitor?
1 Solution
how to fix your speakers
how do you fix the speakers built into the moniter?
1 Solution
Redless screen
the color red is totally missing from my monitor.at times the red returns for a short while then disappears.also there...
2 Solutions
Connecting MAC monitor
I have MAC monitor, 17 inch flat screen with cabinet made from clear plastic. One of the late MAC models. Unfortunately...
1 Solution
How to remove internal capacitor on a...
Does anyone knows and could share their tips on removing and replacing an internal capacitor on a flyback? what are a...
1 Solution
TDA4854 replacement..
Does anyone knows whether I can replace TDA4854 with TDA 4858? Thanks.
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio550:1
Brightness250 cd/m??
Max. Resolution1280 x 1024
Dot Pitch.294 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time8 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s) · Headphone
Audio Input3.5mm Line-in
Regulatory ApprovalCE · UL · cUL · FCC Class B · CSA · TUV-GS · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-03 · TUV-ERGO · MPR-II · MPR-III
Input DeviceKeyboard · Mouse
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal31.5 - 81.1 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical145
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400
Synchronization Range - Vertical55 - 76 Hz
Dimensions
Depth7.87 in.
Height16.84 in.
Width16.46 in.
Weight14.33 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
