FixYa.com
NEC-Mitsubishi AccuSync LCD72V   17" LCD Monitor
All Products > NEC-Mitsubishi > Monitors
Problems with NEC-Mitsubishi AccuSync LCD72V 17" LCD Monitor?
Troubleshooting and Support
Solved Problems for NEC-Mitsubishi AccuSync LCD72V   17" LCD Monitor RSS Feed Post a New Problem
Resolution Notifier pops up every 30-45...
Extremely irritating after a while - Resolution Notifier pops up every 30-45 seconds. Anyone help to solve this?
1 Solution
NEC fs 5197 tv blank screen
hello, i have a NEC fs 5197 TV that has sound, but no picture. it shows all the menu displays, but no channels, or even...
1 Solution
monitor keeps shutting off
17' p205 s7802 on 3rd laptop since 1/10/08 Best Buy in Omaha says it is a known problem but they cant fix just keep...
1 Solution
nec lcd1560v+
Hi: I have a nec multisync lcd monitor , I want to find a driver that could be better than the univ one from xp .The...
1 Solution
Monitor not powering up
I have a Dell 19" Monitor, I recently have run into a problem where it takes my monitor 30minutes to an hour to...
1 Solution
Hansol Flat screen H771 problem after a...
Hansol Flat screen H771. Once unplugged or after a powercut, when it is plugged in again it flickers but won't show...
1 Solution
need help
where can i get a replacement board m713-s3 for the video signal for the monitor thans the small board out of it
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC-Mitsubishi AccuSync LCD72V   17" LCD Monitor RSS Feed Post a New Problem
How do I improve my display's quality
There are some areas of my monitor (only two years old) where there appears to be some noise/static on top of the screen...
Post a Solution
Driver for Vista?
Hi, I'm having intermittant problems viewing photos on the web. I suspect I need to update my driver for Vista. Is...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio450:1
Brightness250 cd/m??
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalISO 13406-2 (Pixel defect guidelines) · Energy star
Synchronization Range - Horizontal31.5 - 81 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical145
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400
Synchronization Range - Vertical56 - 75 Hz
Dimensions
Depth2.4 in.
Height12.9 In.
Width14.8 in.
Weight9.3 lb.
Warranty
Warranty3 Years
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
