20 Most Recent
Directed DEI AutoMate OHD1021 Overhead LCD Monitor - 10.2" Widescreen Flip-Down TFT Detachable DVD / CD Play... Car Video Player Questions & Answers
I purchased a used car
Good day kvanhook!!!
That cables should be connected properly in each corresponding colors (colors by colors).
Then tell me what will happen...If that cable connection did not work just add a comment..
Thank you!!
The cords that connect into the bottom of the DVD
If you would like to have a temporary fix, I would disconnect the cables from the headrest unit, use electrical tape to cover the bare wires, and then go to Radio Shack or another hobby shop and get shrink tubing. Do not cut the shrink tubing along the length of the tube, only cut it to the size of the area that you need to cover. Then you can use a hairdryer on the highest heat to shrink the tubing down in order to cover the exposed wires.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
