20 Most Recent
Denon DCT-670 Questions & Answers
Do I need a housing to replace stock stereo? Or
There are two types of receivers. Double-DIN and single-DIN. Double-DIN is easy to see as it is DOUBLE the SINGLE-DIN's height. If your vechile is a single-DIN it will only be about 3-4 inches tall, while the DOUBLE-DIN is doulbe that 6-8inches tall.
If you have a DOUBLE-DIN in your car and are installing a SINGLE-DIN you will need a housing.
If you have a SINGLE-DIN in the vechile you will not be able to install a DOUBLE-DIN without heavy moddification and cutting.
Please rate if this helped :)
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
