20 Most Recent Pelco DX1000 Questions & Answers
You can also try "Standby Helper"if you have the occasional issue of the projecter going off ..u can created a task in task scheduler that runs with a 30 second delay on startup.
Pelco DX1000 | Answered on Dec 07, 2014
FileASSASSIN from malware antibytes can unlock it..but be carefully as u can delete file..
Pelco DX1000 | Answered on Apr 02, 2014
To reset the password for the DX7000 follow these steps: Reboot the system During the boot process, before "Starting Windows" message comes up, press the F8 key repeatedly to enter Safe Mode When the boot options menu comes up, select boot to command prompt only If you get the scan disk screen, you've gone too far and have to reboot. At the command prompt "C:\>" type cd windows and press enter. At the prompt C:\WINDOWS>" type edit system.ini and press enter. When the edit screen opens up, scroll down to the line beginning with the word "shell" Insert a semicolon (;) before the word shell = ;shell Save the file, exit, then reboot the system (You may have to hit ALT on the keyboard to get the File menu to come up) Press ALT+F followed by X and select Yes to the save and exit prompt Press CTRL+ALT+DEL to reboot. The system should now boot to a regular desktop, edit the system registry: Click on the Start button Select Run In the Open field, type in REGEDIT, then click on OK Find the password entry and delete the password: Double click on HKEY_CURRENT_USER Double click on SOFTWARE Double click CyberNetic Double click DVR Double click 1.0 On the right-hand side, locate the word Password and double click it Delete the contents of the Value Data field and click OK Close the regedit window Make the system bootable into DX7000 software: Click START Select Run In the Open field, type SYSEDIT then click OK Click on the SYSTEM.INI window within the System Configuration Editor window Locate the SHELL statement and remove the semicolon that was placed there earlier Close the System Configuration Editor window Click OK when it prompts you to save changes made to SYSTEM.INI file Restart the system (Click START > SHUT DOWN > RESTART) Click OK
Pelco DX1000 | Answered on Nov 06, 2013
Use the analog monitor output on the back of the DX1000 and a BNC to RCA converter you can pick up at any local hardware or electronic store
Monitor out put on the back of the DVR.
the default password is 0000 try that.
Pelco DX1000 | Answered on Nov 30, 2009
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Pelco DX1000 | Answered on Oct 22, 2009
Will not work. the OS is in a partition on the original HDD....you best bet is to send it in for a repair call 1-800-289-9100 24/7 to get a RA #
yes contact service repair at 1-800-289-9100
This DVR dose not support that...You can either see one camera full screen or see all 4 in a quad screen depending on how many cameras you have and how may of them are enabled.
If the Preview feature in the Camera menu is On, you can view live video on the monitor.
Video is displayed full-screen only if one camera is turned on. If more than one camera is
turned on, video is shown in a quad view. Sorry but its not going to be able to do what you are looking for...Pelco didn’t put that feature in their small DVR until the DX4000 series......Good Luck and let me know if this helps,
cbinny1
Converting Pelco exported video files
WHAT IS A DVR?
A DVR is a video recording and pl
ayback device that inco
rporates all of the essential capa
bilities of a VCR but adds significan
t advantages. Like
a VCR, video is recorded from one or more cameras and stored for later playback and retrieval; however, in a DVR, video data is
recorded and
stored on a hard disk instead of
magnetic tape.
Storing video in
this manner facilitates
instant, rand
om access to data, as opp
osed to sequential
access inherent to tape-based recording. This means no fast-forwarding or rewinding is necessary to locate the data a user want
s to view or
export. Another key advantage over tape is decreased maintenance. With no need to replace tapes, DVRs with hard disks can be le
ft unattended
for extended periods of time. Since video remains in the digital domain, data is easy to store, transport, and manipulate. Unli
ke analog video
recordings, digital data does not suffer from a loss in quality wh
en copied or moved from device to device. Because DVRs rely o
n hard disks
instead of tape, data storage is virtually unlimited. Video data
can also take advantage of comp
ression technology
to increase
the efficiency of
storage media. Modern DVRs, such as the DX8000, allow users to record, play back, and view live video simultaneously. Keeping d
ata digital
means video can be easily backed up to a variety of storage media.
It also means that alphanumeric
information, such as date, t
ime, and
transaction statistics,
can be synchronously recorded with video.
Pelco Televison... | Answered on Jun 20, 2015
Its a software problem
Pelco Televison... | Answered on Feb 09, 2010
Google (brand)(DP26647)(manual) without parens OR contact the manufacturer/distributor directly.
Televison &... | Answered 2 hours ago
Pelco DX1000 Logo
Popular Tags
15 questions posted
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pelco Televison & Video
Most Popular Question
need new hard drive
  • Televison & Video
