Estate TGDS740JQ Gas Dryer
Problems with Estate TGDS740JQ Gas Dryer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Estate TGDS740JQ Gas Dryer RSS Feed
Click here to get instant support from our best Experts!
View More Results for Estate TGDS740JQ Gas Dryer
Questions and Unsolved Support Problems
Unsolved Problems for Estate TGDS740JQ Gas Dryer RSS Feed
Answer
My GE gas dryer's exhaust smells like a gas grill and my clothes smell the same. The dryer is 3... (More)
Answer
We just bought a used gas dryer from craigslist...I used it for the first time last night and my... (More)
Answer
dryer gets hot but not hot enough takes to long to dry cloths
Answer
Dryer smells like gas replaced gas line to dryer
Answer
my gas dryer's exhaust smells like a gas grill and my clothes smell like they've been dryed on a gas... (More)
Find a Manual
Estate TGDS740JQ Gas Dryer Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Dryer Heating Problems
I have been getting a lot of problems with dryers not heating right. A lot of sloution have been that people have been cleaning out their heat vents... written by rjhahn
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
How to change your dryer from 3 wire to a 4 wire power cord. (short and...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power... written by MNTECH
Washer and Dryer Repair manuals and Parts
Please rate a Fix Ya!!! Thanks jj505 For all Washers/Dryers/Parts http://laundry.manualsonline.com/ written by jj505
Possiable Manuel HELP OR ORDER PARTS LINK
Please rate a Fix Ya!!n Thanks jj505 http://www.repairclinic.com/Home.aspx written by jj505
SAVING TIME & MONEY $$$
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if... written by DRRXR
Dryer operates but will not heat.
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six... written by gregorymholt
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for TGDS740JQ Gas Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Ratings for the Estate TGDS740JQ Gas Dryer
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Find a Warranty
Specifications for Estate TGDS740JQ Gas Dryer
Key Features
Power Source
Gas
Load Type
Front Loader
Dryer Type
Home Dryer
Other Features
Cycles
5 Cycles
Moisture-Sensor
With Moisture-Sensor
Dimensions
Overall Depth
26.75 in.
Overall Height
42.38 in.
Overall Width (Display)
29 in.
Warranty
Warranty
1 Year
Estate Contact Information
Main support number1-800-253-1301
Describe your problem:
Top Dryers Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
