20 Most Recent
Metrik Amplifiers MAX-1202 Car Audio Amplifier Questions & Answers
I get engine noise when
check on radio shack and get a ground loop isolator and that will be solve your problems
11/11/2010 6:07:15 PM •
Metrik...
Answered
on Nov 11, 2010
Shorted Speaker outputs
Its probably in the amp if it is you cant do anything about it unless u know anything about amp circuit boards
7/25/2010 12:41:52 PM •
Metrik...
Answered
on Jul 25, 2010
Instalacion
ask ...how can i help u and how ..like what size wires to buy ...ect ect ect...then i can help...
2/24/2010 3:18:17 AM •
Metrik...
Answered
on Feb 24, 2010
My power terns on but then the red lite comes on
I am not sure but it sounds like it is going into protect mode. Turn your levels to minimum and see if it stays green. You should also check the speakers to be sure they are not shorted or grounded. Check the supply voltage and be sure it is above minimum and below maximum specifications.
Good Luck,
Gilshultz
12/3/2009 12:31:18 AM •
Metrik...
Answered
on Dec 03, 2009
Amp messed up got 24 volts instead of 12 how to fix
Here is what I need you to do so that I can help you try to fix this. I need you to open up your amp take some pictures. I will need some of the overall view, then take two seperate picteures closer dividing the amp in half. They should look like one really big picture of the overall amp. Then finaly I need you to take some pictures of the problem. I am sure that witht the pop and smoke that you saw and heard you shold be able to find the problem really quick. With all of this and from the way is sounds this could be a really easy fix. onle last thing do you have a soldering iron, solder and a wet sponge.?
4/11/2009 1:12:11 PM •
Metrik...
Answered
on Apr 11, 2009
Subs wont play music
Sounds like your RCA's are the source of your problem. Unplug your RCA's before you turn your car on. You may need to isolate your RCA's and the ground wire on the back of your head unit.
2/11/2009 12:41:58 AM •
Metrik...
Answered
on Feb 11, 2009
Well is their any ways to fix a car stereo amp??
One of the more confusing things with a car stereo can be when the amplifier goes into protection mode. One minute it's working and the next minute it's not. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
1. Try to determine the cause. Amp's can go into protection mode for several reasons. Knowing what happened before it cut out can help determine how to fix it. Did the amp not work as soon as it was turned on? Did it happen after blasting for hours (may be thermal overload and it needs to cool)? Did it cut out after you hit a bump (a wire connection may have come loose)?
2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amp touching metal.
Remember that an amplifier should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier. Always mount the amplifier to a non-conductive surface. An easy way to accomplish this is to mount the amplifier to a wood board and then mount the board to the vehicle.
3. If the amp is OK in this torn down state keep adding the other wires back on until you find what causes the problem. Add the RCA cables first. Then add the speaker wires one at a time. If the speaker wires cause the problem then they are probably touching metal. Check to make sure that a speaker wire isn't being pinched somewhere between the amp and the speaker. Also check that the speaker wire or speaker terminals aren't touching the vehicle metal near the speaker opening. Rear decks and door panels can easily touch unprotected speaker terminals if not properly installed.
If the problem starts occuring when you connect the subwoofer wires to the amplifier you may have your subwoofers wired at too low an impedence. First check the specs on your amplifier to make sure what kind of loads it is stable under. Then go here and check the wiring configuration to make sure that your load is not too low:
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor. However local repair shops may be cheaper if it is just a small repair. Compare the manufacturer's repair rate to that of a local shop. If you don't know the reputation of the local shop it may be better to send it to the manufacturer who will have working knowledge of the amp and parts readily available.
1/3/2009 3:07:33 PM •
Metrik...
Answered
on Jan 03, 2009
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
