FixYa.com
Ohm Crystal Mobile Sound CADT 600.2 2Channel Amplifier 1200 Watts Car Audio Amplifier
All Products > Ohm > Car Amplifiers
Problems with Ohm Crystal Mobile Sound CADT 600.2 2Channel Amplifier 1200 Watts Car Audio...?
Search inside Ohm Crystal Mobile Sound CADT 600.2... Knowledgebase
Troubleshooting and Support
Solved Problems for Ohm Crystal Mobile Sound CADT 600.2 2Channel Amplifier 1200 Watts Car Audio Amplifier RSS Feed Post a New Problem
Amp Power
Hi, I have an Alpine MRV-1507 2channel amp running two Alpine SWR-1240 (300watt RMS 1000watt max) subs. The amp is...
1 Solution
protection light comming on.
When I connect the RCA's to the amplifier and try to turn on the amp the protection light is turning on. I would like...
1 Solution
eclipse XA1000 and protect mode
I recently replaced my two 12" subs due to a problem in the voice coils. It seems they were pushed beyond their...
1 Solution
Smoking Amp/Fuse Blowing
Ok im having similar problems as you seen up above. im not good with electronics as far as checking the B+ thing lol but...
1 Solution
Amp
I have installed a amp into a figerglass boat, the radio is new and is working. However after connecting the amp I have...
1 Solution
Audio system makes extra noises... pops
Audiobahn Sub: AW1206T & Amp: A8002T subwoofer extra noise/pop i have also posted this under the subwoofer page...
2 Solutions
power supply
if the amp is not getting enough power consistantly will the amp heat up because is working harder. if so would a...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Supported Models
Bridged at 2
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
