20 Most Recent Pyle - Elite: 2 Channel 2400W Elite Series 2680 Car Audio Amplifier Questions & Answers
It sounds to me like there is a dirty connection or a failing component in your stereo. Being intermittent like you've described, is hard problem to figure out. It could be just the connection you are getting at the speaker terminal. But, If you aren't shy about opening up your stereo to see the guts, try getting some denaturated alcohol and clean the connectors inside. Then if you are familiar with soldering you could check the connections in the driver circuts and see if you can re-flow some of the connections. I had that problem with my receiver. The video output was be flaky so I flowed some new solder on some terminals and it works perfectly.
I hope things work out.
-Andrew Hawkins
Pyle - Elite: 2... | Answered on Mar 24, 2009
You probably won't unfortunately. It's a $150 speaker. That means that the chances of having a service manual available are slim. Your best bet is checking the amp chip and the power supply. If anything is obvious you will find it.
Pyle Car Audio &... | Answered on May 09, 2019
http://www.fixya.com/tags/fix_white_screen/car_audio/pyle
Pyle Car Audio &... | Answered on Feb 15, 2019
All speakers in a car need to be hooked up to some kind of amplifier. However, if the current radio has a good enough amplifier, this is not mandatory.
Pyle Car Audio &... | Answered on Jan 17, 2019
There's a specific colored(reverse light)cable that one of the wires on your camera needs to be hooked up to in order for that feature to be enabled..
Pyle Car Audio &... | Answered on Nov 12, 2018
As long as the pins are in the same location and correct order then it shouldn't be an issue and if the wattage is the same u should be fine
Pyle Car Audio &... | Answered on Nov 05, 2018
The manual for the Pyle PSWDV60GN dive meter/watch is available on the product page: https://www.pyleaudio.com/sku/PSWDV60GN/Advanced-Dive-Meter-With-Water-Depth,-Temperature,-Dive-Log,-Auto-EL-Backlight . Click on the Manuals and Downloads tab on the right side of the page. Click on the link to download the manual.
I hope this helps.
Pyle Car Audio &... | Answered on Oct 25, 2018
What is "stoped"
Pyle Car Audio &... | Answered on Sep 29, 2018
Car Audio & Video Logo
1 questions posted
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pyle Car Audio & Video
Most Popular Question
panasonic stereo help
  • Car Audio & Video
