20 Most Recent Fisher and Paykel DG06 Gas Dryer Questions & Answers
Not drying, sounds like a belt slipping, squeal
replace drum rollers
10/25/2010 12:45:34 AM • Fisher and... • Answered on Oct 25, 2010
Hello, My Fisher Paykel dryer
The motor is going bad...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
9/21/2010 1:25:22 AM • Fisher and... • Answered on Sep 21, 2010
The light inside the dryer comes on when the door
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/12/2010 4:13:45 AM • Fisher and... • Answered on Sep 12, 2010
I WAS TOLD A FISHER PAYKAL DRYER CAN BE CONVERTED
I am in agreement. No can do. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4/13/2010 2:57:27 AM • Fisher and... • Answered on Apr 13, 2010
2answers
My fisher and paykel dryer timer for 90 minutes only lasts for 20 minutes and then its completed how do I fix this.Thanks
You may have bad timer or bad motor windings ? does it shut off after 20 minutes and can u start it back up right away? if not start fast then bad motor windings. try using a diff dry setting and see if it does same thing you may need to check the cycling thermostat too test 4 bad motorwindings4-undefined-undefined-0_0.jpg fuses dryercyclingfuse-undefined-undefined-2_2.jpg fuses highlimit thermostatlt-undefined-undefined-5_1.jpg knob-on-dryer-broken-undefined-undefined-9.jpg
12/13/2021 2:59:46 AM • Fisher and... • Answered on Dec 13, 2021
Dryer shuts off during cycle. Usually can be
cycling thermosta
8/21/2021 9:02:52 AM • Fisher and... • Answered on Aug 21, 2021
F & p de35 clothes dryer gets hot say 20 mins running then cuts out ,nothing cools for say 5 to 10mins away it goes ,i have changed the motor was told the thermo switch in was faulty betta after still
Dryer runs then shuts down wont start up for an hour: or 20 minutes Bad motor windings also check for a b ad cycling thermostat test 4 bad motorwindings4-undefined-undefined-0.jpg blower insides07-undefined-undefined-2.jpg fuses highlimit thermostatlt-undefined-undefined-4_0.jpg backofdryer-undefined-undefined-7_0.jpg
8/21/2021 9:02:23 AM • Fisher and... • Answered on Aug 21, 2021
My F&P gas dryer runs but I can hear the combustion fluttering during drying process and of course it’s taking longer than normal. It does NOT shut off like others above. Lint has been thoroughly cleaned from all areas.
ELECTRIC Dryer no heat or little heat, or shuts down to fast: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity it should show OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale at 20K ohms. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12. (1200) ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run, the heater should not heat in order not to create a fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater. Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?) Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity. A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats. Read more : https://www.youtube.com/watch?v=wVTBrGMql7g http://www.ehow.com/info_12203962_check-dryer-thermistor. GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE https://www.youtube.com/watch?v=MMP7BW1lLs4 gas safety valve gas breakdown-undefined-undefined-0.jpg gasdryer guts-undefined-undefined-2.gif gas safetyvalvelt-undefined-undefined-4.jpg
8/21/2021 9:02:16 AM • Fisher and... • Answered on Aug 21, 2021
F/p dryer start button starts flashing when pushed once starts on second push and turns off after about 1min
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle? 1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used. 2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer. Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while Electric dryer no start does nothing Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING. NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position. If you hear a humming/clicking sound from motor area you more than likely have a bad motor. Try this test out to see if u have weak windings or relay/capacitor on motor. Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings Another thing to check is the belt safety switch. With a multi meter. Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad. https://www.youtube.com/watch?v=MhVUEhngZMg beltswitcht 5-undefined-undefined-0_0.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-1.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-2.jpg knob-on-dryer-broken-undefined-undefined-3.jpg knob-on-dryer-broken-undefined-undefined-5.jpg knob-on-dryer-broken-undefined-undefined-4.jpg teststartswitchr1-undefined-undefined-6.jpg teststartswitchr1-undefined-undefined-7.jpg teststartswitchr1-undefined-undefined-8.jpg teststartswitchr1-undefined-undefined-9.jpg timer motor wires-undefined-undefined-10.jpg timer motor wires-undefined-undefined-11.jpg timer motor wires-undefined-undefined-12.jpg timer motor wires-undefined-undefined-13.jpg timer motor wires-undefined-undefined-14.jpg
8/21/2021 9:02:12 AM • Fisher and... • Answered on Aug 21, 2021
Fisher and Paykel Dryer making noises after moving it
DRYER MAKES NOISES. A loose or worn BELT can make funny noises Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt. The glides on drum worn and making metal to metal contact. The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out. CHECK FOR LOOSE BELLOES inside the drum Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing. The blower: Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel. The bearings: The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process. The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it. The drum rollers or castors: It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them. GOD IS GOOD !!!! drum-glidesr-undefined-undefined-0.jpg drum support dryer-undefined-undefined-2.jpg roller bad dryer rroller-undefined-undefined-5.jpg roller good dryer roller-undefined-undefined-9.jpg
8/17/2021 6:48:29 AM • Fisher and... • Answered on Aug 17, 2021
Dryer not heating up, lint filter keeps beeping & seems to be water pooling near condenser. We emptied water tank, cleaned lint filter & condenser filter but it is still doing the same thing
ELECTRICDryer no heat or little heat, or shuts down to fast: Checkyour venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuityit should showOHMS CLOSED CIRCUIT. If not its defectiveor has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter(VOM)set to the RX1 scaleat 20K ohms. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12. (1200)ohms.If the reading is higherohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,OR?you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposedto be if the motor does not run, the heater should not heat in order not to createafire but ifthe motor is not running,andthe heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater. Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In somedryer'sthecontrol panel relies on athermistorrather than aCYCLING thermostatto regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when thethermistorindicates that more heat is needed to keep the air temperature constant inside the drumthis is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?) Lastly check your moister sensor.( located inside the dryer door usually) Especially if machine seems to shutdown early and clothesare still wet. Test with a meterat room temperatureand it should show continuity. A failed moisture sensor will affect the dryer run timein the automatic moisture sensing cyclebut it will not affect the heatingof the dryer or the timed cycle.Which are reflected by the thermostats. Read more : https://www.youtube.com/watch?v=wVTBrGMql7g http://www.ehow.com/info_12203962_check-dryer-thermistor. GOD IS So GOOD !!!!AND THAT'S WHY MY ADVICE IS FREE heating-element-bad coil-with-housing-240v-undefined-undefined-0.jpg drum glides dryer door-undefined-undefined-2.jpg vent tube bad -undefined-undefined-5_1.jpg venting in cabinet clogged-undefined-undefined-9_0.jpg test dryer element-undefined-undefined-14_0.jpg
3/28/2020 8:51:02 PM • Fisher and... • Answered on Mar 28, 2020
Fisher and Paykel dryer making a banging noise
D Floyd Kolb--
Our dryer only makes the knocking sound when it's going in the reverse direction. Would you be able to narrow down the cause from this info? I've removed the lint filter and cleaned/tightened. But nothing has changed.
Thanks!
5/26/2019 4:18:59 PM • Fisher and... • Answered on May 26, 2019
What is the cause of a fisher and paykel celvinator auto sensing dryer that starts well 90% of the time yet stops 2 minutes later?
Check the filters are clean and that the air ducts are not blocked. The sensors pick up temperature change and any restrictions will cause the machine to cycle on or off at the wrong times. Its possible the sensor itself is faulty.
5/3/2019 4:24:32 AM • Fisher and... • Answered on May 03, 2019
Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
1/2/2019 1:08:58 AM • Fisher and... • Answered on Jan 02, 2019
My Fisher and Paykel dryer keep stopping. It is heating up but keeps stopping after a few minutes - help
Could be overheating because the exhaust vent is clogged. Check that out.
12/24/2018 10:16:22 AM • Fisher and... • Answered on Dec 24, 2018
I have a Fisher and Paykel Dryer DE5060MI inverted. So I have replace the sticker instructions but the LED display is upside down, can I fix this or not?
7 Adjust the display to read correctly on an inverted panel: ?? For DE7060M and DE5060M press and hold the 'Keylock' and 'Heavy' buttons for three seconds. ??
12/4/2018 9:21:08 AM • Fisher and... • Answered on Dec 04, 2018
Fisher and Paykel DG06 Gas Dryer Logo
Popular Tags
8 questions posted
Top Fisher and Paykel Dryers Experts
Virgil Watts
john h
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Dryers
Most Popular Question
fisher paykel dryer
  • Dryers
