20 Most Recent
Fisher and Paykel DG05 Gas Dryer Questions & Answers
Why doesn't the start button work?
Could be Start Button is bad. Could be the Door Switch is bad. Could be the motor is bad. Could be the Thermal Fuse is bad. Not sure without model #. Good Luck!
Is there a way to test motor
Is the problem motor not running, or drum not turning? The motor itself is very quiet. Do you have a broken belt? If no motor running, check door switch or start switch. Smell motor. Does it smell burnt?Are the windings copper colored or
Fisher & Paykel gas dryer
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
Clothes get caught between drum
Hi pmccabe513...
Your problem with the clothes getting caught between the drum and body is caused by too much wear on your felt seal between the drum and body of the dryer...replace your felt seal and that should solve that problem.
The heating problem:
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer.
The problem could also be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
My Fisher D04 makes a continuous load squeaking
Hi
The issue seems to be with a bad/worn out belt assembly that
should be replaced. You have to completely take it apart to replace it. Hope
this helps...please post back for further assistance.
Daniel
