20 Most Recent Denon AVR-2801 Receiver Questions & Answers
Push control back to digital or where it was originally! Or play stu--d and just get outta there.
Denon AVR-2801... | Answered on Aug 26, 2017
Have you checked the scart leads. They are really good at causing these kinds of problem.
Denon AVR-2801... | Answered on May 29, 2017
You need to do the input assign. The receiver doesn't yet know that you plugged a cable in to one of the Optical ports.
If you have done the above, then the next thing is to check the amp's Mode button. This cycles the input between Optical and analogue audio inputs.
Denon AVR-2801... | Answered on Sep 12, 2014
Maybe start with speaker test tones to verify the hardware instead of messing with live audio modes.
http://www.retrevo.com/support/Denon-AVR-2801-Receivers-manual/id/363bh831/t/2/
BTW: the powered subwoofer is supposed to be driven by the 'Subwoofer' Pre-Out.
What input are you using that allows audio when you select EXT IN AND the other modes? That is a specialized analog input for 5.1 analog equipment ONLY. (Page 32)
Denon AVR-2801... | Answered on Oct 30, 2011
what do you mean our fees, for what part is your question
Denon AVR-2801... | Answered on Aug 12, 2011
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Denon AVR-2801... | Answered on Apr 03, 2011
Just moved and got mine hooked up last week. Was working great and now I can't get anything. The reassuring "click" I've always heard when I switch between inputs is gone. Anyway enough about my issue, what specifically are you having trouble with?
Denon AVR-2801... | Answered on Sep 14, 2010
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Denon AVR-2801... | Answered on Jul 27, 2010
I cannot access the setup menu on the unit display or via the s-video monitor out -- everything was working fine a few days ago. I have reset micro, unplugged all night, reset again, and still cannot get to the menu in order to correct connections, esp for digital. My problem is on the avr5600 but seems like this happens on many of the denon units
Denon AVR-2801... | Answered on May 29, 2010
Denon AVR-2801 Receiver Logo
32 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
video performance question
  • Audio Players & Recorders
