Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer
Problems with Hoover Nextra HNWL 3166 Front Load All-in-One...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Hoover Nextra HNWL 3166 Front Load...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer RSS Feed
View More Results for Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer
Questions and Unsolved Support Problems
Unsolved Problems for Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer RSS Feed
Answer
how do i replace drum bearings on my hoover/ dryer washing machine.
Answer
i select to dry and the machine goes around and all that happens is the orange lite goes on then off... (More)
Answer
I have a hoover hnwl 6136, and it's not drying properly. Presume I need to clean the filter but I... (More)
Answer
hoover nextra washing macine does not work clothes are wet and locked in. No program setting will do... (More)
Answer
Hoover Nextra HNL 7166 Starts program, water starts coming in and drum starts to rotate after couple... (More)
Answer
Hi my Hoover washer dryer (hnwl3166)has an intermittent problem, it wont drain, i have removed the... (More)
Find a Manual
Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Replacing a Lid Switch
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how... written by jsrock516
How to Drain a Clothes Washer When the Spin Does Not Work
InstructionsThings You'll Need: Buckets (at least two or three) Pipe cutter Screwdrivers Wrench Draining the machine Step 1 Locate the drainage hose,... written by sivaranjini
How to Repair Leaking Washers
InstructionsThings You'll Need: Fashlight Pliers Screwdriver Hoses and parts (as needed) Step 1 Determine where the leak is coming from. Use a... written by sivaranjini
Do it Yourself Repair a Washing Machine
Power IssuesIf you've loaded in the clothes and pushed the on button to get no response, you have some sort of power issue. First, start by checking... written by sivaranjini
How to fix a washing machine that won't drain.
InstructionsThings You'll Need: Screw driver/socket set bucket towls Step 1 Check and make sure that the washer is plugged in. I know that sounds... written by sivaranjini
How to Diagnose Washing Machine Problems
Instructions Step 1If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut... written by sivaranjini
WhirlpoKenmore washing machine -- can hear motor running, nothing happens
Whirpool (and Kenmore, which are made by Whirlpool) washing machines do not have belts to drive the transmissions. They use a motor coupling, which... written by wiringlunati
Noise from Whirlpool/Kenmore washing machines / agitator not turning
Many toploading Whirlpool (and Kenmore -- they're made by Whirlpool) washing machines have a ratcheting agitator. The agitator moves only one... written by wiringlunati
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Nextra HNWL 3166 Front Load All-in-One Washer / Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Rate and Review the Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer
Write a review:
Rate this product:
Would you recommend the Nextra HNWL 3166 Front Load All-in-One Washer / Dryer to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Hoover Nextra HNWL 3166 Front Load All-in-One Washer / Dryer
Key Features
Washer Type
Load Type
Front Load
Weight Capacity
8.82 lb.
Wash
Wash Presets
Hand Wash, Mixed Colors, Wool, Wrinkle-Free, Soaking
Spin Speeds
max. 1600 rpm
Temperature Levels
Infinite
Washing Method
Drum
Extra Settings
Quick Wash
Convenience
Control Features
Time Remaining Indicator · Dial Controls
Efficiency
Energy Efficiency
C
Water Consumption per Wash
14.27 Gal.
Wash Efficiency
A
Other Features
Exterior Color
White
Dimensions
Overall Depth
23.23 in.
Overall Height
33.46 in.
Overall Width (Display)
23.62 in.
Hoover Contact Information
Main support number1-800-944-9200
Describe your problem:
Top Washing... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
