Troubleshooting & Support
Hot Topics:
Problems & Solutions
remote wont work
Hi, The first thing to check for is corrosion of the battery terminals. They can become dirty with battery acid that leaks out over a period...
can't see anything on the TV screen
connect you system to a VGA monitor. reste your setting to RCA
While connected via VGA cable
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory...
Words "roll" on Screen
sir, where did you purchase your player?i think theres a problem with your COLOR SYSTEM SETTING...the color system(REGION NUMBER) of your...
CAVS DVD-203g remote control
my cavs203g video out put doesnt work and dont have remote
How do I fix the vga output in my cavs 203g
what is wrong with the VGA output? the connector? no display? please clarify
Dvd password? what is it?
if you bought this dvd player new and you or someone else have not changed the parental password, it should be the default password,...
Where can I get my cd player repaired?
If there is an authorised service center for your CD brand, get it repaired from there. If not, contact any experienced service tech.
My AWA UC550AR Micro System does not recognise...
The problem is in the laser pickup, overtime it becomes weak until it can no longer read the disc, the only option is the complete...
RCA Model No: RCD330-B does not play the CD; it...
The laser pickup is at the end of life, the only option is to replace the whole assembily which would cost more than the machine is worth,...
manual for model #RS1286
You may download a copy of the manual here.
what's the step to use Autocom CDP Pro?
http://www.xcardiag.com/wholesale/autocom-cdp-pro-compact-diagnostic-partner-pro-new-version-release-2011.03.html the video...
discs won't play
The laser pickup assembly is the problem, try a CD cleaning kit and follow instructions, if this fails! the assembly needs to be replaced,...
no volume from speakers
The audio output transistors or ic is shorted, first! check speaker wiring for shorts, if okay! the above parts will need a attention.
CD will start and then stops playing - cannot use...
The laser pickup head that has the ribbon cable attached has become defective and is intermittent. Unfortuneately the cable is hard wired...
See all Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Solutions
Unsolved Problems
I have purchased the cavs
I have purchased the cavs 203g with usb. Can I use an external hard drive with a usb 3 buss charge. Will the external...
I have done something to
I have done something to cause the file numbers to be off by one number, i.e., when I push file 18 from the external...
203G unit works fine, but i now have 2 remotes and
203G unit works fine, but i now have 2 remotes and neither work...it's like they have lost their program
Im looking for bluelaser karaoke player manual
Im looking for bluelaser karaoke player manual desperate. rothwellrosina46@gmail.com
the player reads the disc
the player reads the disc but nothing happens when you press the play button
i clicked on the VGA setting and now I can't
i clicked on the VGA setting and now I can't get a picture? How do I reset with no picture?
music is fading in and
music is fading in and out
my remote will not bring up the menu or settings
my remote will not bring up the menu or settings to t.v. but works otherwise. i messed up and hit the wrong setting for...
I changed to an HD TV and stared having delay on
I changed to an HD TV and stared having delay on the vocals when singing. I used RCA cable but still havibg the same...
The problem is it is
The problem is it is not reading any disk. It is saying NO DISK.. Thanks for any help please..
See all Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Problems
Manuals & Guides
TopDo you have a manual for Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player? - Upload it to FixYa!
Upload a manual for Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player
What's your problem?
Fix-O-Meter
2,427
2,427 people have viewed this product
- 35 people asked about this product.
- 7 people found solutions for this product.
- 0 people have added this product. Be the first!
how to clean...
How to convert...
A quick fix for...
