My Model no. BATT-2P 7.4v 3600mAh Li-ion battery has died and I need a new one. Where can I find...
(More)
My Model no. BATT-2P 7.4v 3600mAh Li-ion battery has died and I need a new one. Where can I find one.
I have no sound on my unit Kawasaki PVS10921- but movie playing - do not know how to fix this? Have...
(More)
I have no sound on my unit Kawasaki PVS10921- but movie playing - do not know how to fix this? Have read the manual and do not see how to get the sound to play.
The device that holds the eye will not move. I can push it back myself but when I load the dvd it...
(More)
The device that holds the eye will not move. I can push it back myself but when I load the dvd it comes forward and stays. I've cleaned the eye and the dvd I tried to use, but nothing. Everything else seems to been in good working order. Help LB
where do you get parts for the Kawasaki DVD player PVS10921 I need the adapter to play and power...
(More)
where do you get parts for the Kawasaki DVD player PVS10921 I need the adapter to play and power cord
can the rechargeable battery pack batt-2p power the portable dvd player pvs1665 while it's plugged...
(More)
can the rechargeable battery pack batt-2p power the portable dvd player pvs1665 while it's plugged in?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
