20 Most Recent
Comdial 8012S-GT Corded Phone Questions & Answers
"No such station" message appears when I try to
It means there's "No Such Station" :-)
VM extensions are part of the system, usually the pilot number is the lowest of the sequence. If your button got reprogrammed and you're dialing a number that doesn't exist, you'll get that error.
Start by dialing like 22, 23, 24, 25 (4 highest ports in a 0816 DSU). Reprogram the button by Intercom **1 press the button and dial 6xx where xx is the VM pilot number.
Carl
How do I set the time on my phone?
Set system clock:
Press Intercom then *#746*
Dial 01
Dial 00 - 99 for year (10)
Dial 01 - 12 for month (01)
Dial 01 - 31 for day (04)
Dial 00 - 23 for hour
Dial 00 - 59 for minute
Press Speaker to end.
Headset compatability
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
COMDIAL PHONE
You cannot set the time directly on the individual phones, this is something that must be set for the entire PBX.
You can find manuals for this series of phones here:
http://home.maine.rr.com/sfg2/COMDIAL/index.html
Comdial edge 120 incoming call handling help
It seems like you're trying to configure a phone system or a specific phone to have incoming calls ring on multiple extensions simultaneously or forward to another extension if not answered. The exact steps can vary depending on the phone system or model you're using. If you provide more details about the phone system or model, I can offer more accurate instructions. In the absence of specific information, here's a general guide on how you might achieve this:
**For Most Phone Systems:**
1. **Ring All Extensions:**
- Log in to the phone system's administration interface.
- Locate the call forwarding or call distribution settings.
- Look for options related to "Hunt Group," "Ring Group," "Call Distribution," or similar terms.
- Create a group that includes the extensions you want the incoming calls to ring on.
- Assign the group a number or label.
- Configure incoming calls to be forwarded to the assigned group number or label.
2. **Forward After Rings/No Answer:**
- Within the same settings area, look for options related to "Call Forwarding" or "Follow Me."
- Configure the settings to forward calls to another extension or voicemail after a certain number of rings or if there's no answer.
**Example for Asterisk-based Systems (such as FreePBX):**
- Log in to the FreePBX administration interface.
- Create a Ring Group.
- Add the extensions you want to include in the group.
- Set the Ring Strategy to "Ringall" or "Ring All Available."
- Specify the Ring Time (how long it should ring on each extension).
- Save the settings.
- Create a Follow Me setting.
- Add the destination extension(s).
- Set the Ring Time (how many seconds it should ring).
- Configure the Follow Me List to go to the next destination if there's no answer.
Please note that terminology and options might differ based on your phone system's manufacturer and model. It's important to consult your phone system's documentation or seek help from your IT department or phone system administrator if you're not familiar with the settings or if you're dealing with a complex setup.
Keep in mind that making changes to a phone system's configuration can impact its functionality, so it's a good practice to do so during non-peak hours or with proper testing to ensure everything works as expected.
I need help resetting the password to my Comdial 7260 00 voicemail.
To reset the password on your Comdial 7260 00 voicemail, follow these steps:
- Dial the voicemail extension from your phone.
- When prompted, enter the default password. The default password is usually "0000" or "1234".
- Follow the prompts to change your password. If you are not prompted to change your password, press "9" for the mailbox options menu, then "8" for the password menu.
- Enter your new password when prompted. Make sure to choose a secure password that you can remember.
- Confirm your new password when prompted.
- Hang up the phone to save your changes.
If you are still having trouble resetting your password, you may need to contact your voicemail administrator or Comdial customer support for further assistance.
