20 Most Recent Hoover HCA390K Bottom Freezer Refrigerator Questions & Answers
The ideal refrigerator temperature is 35° F (1.6° C). You're not hugging the danger zone like you would be at 40° F (4.4° C), and you're distancing yourself sufficiently from 32° F (0° C) that you don't freeze half the stuff in your refrigerator.
Not cool enough!
Hoover HCA390K... | Answered on Nov 01, 2017
I had the same problem, the fridge insulation has gone and this means you need to replace it. There is no hope for it unfortunatly.
Hoover HCA390K... | Answered on Oct 14, 2013
This issue is frequently seen when the valve that diverts refrigerant between the top compartment and lower compartment is stuck closed.
It is advisable to turn the whole unit off to prevent any further damage within and contacting a domestic appliances service engineer in your area as soon as you can to have the valve replaced and the unit regassed (If neccessary 50/50 if it does or not)
Please also be aware that this can be an expensive repair and in many cases it is more cost effective to replace the unit than get it repaired.
If you elect to replace be sure to buy one with a lengthy warranty as had this unit have been under warranty Hovver will have paid for the repair.
Hoover HCA390K... | Answered on Apr 26, 2011
What about the light switch,lamp'S housing and in worst case a burn wire ? Good luck!
Hoover HCA390K... | Answered on Jun 29, 2006
check with hoover , we have no idea here
Hoover... | Answered on Mar 14, 2018
Your users manual should tell what the codes stand for concerning your particular unit. Some codes will only apply to a certified technician and will not be revealed.
Hoover... | Answered on Oct 16, 2017
Adjust the temperature.
Hoover... | Answered on Sep 05, 2017
The door needs adjusting as the seal is usually magnetic.
Hoover... | Answered on Jul 16, 2017
Possibly a re-gass after repair may solve the issue.
Hoover... | Answered on May 13, 2017
it's not leaking water.. it's condensation running down the back of the fridge.. normally this is channelled into a hole that has a tube on it, that allows the water to go to a drip tray on top of the (warm) compressor, which then evaporates it.. Please re-check for a "V" shape moulding on the back if the fridge.. there SHOULD be a hole smack bang in the middle, which may have clogged up in the pipe with gunk, causing water to refreeze and block the hole completely.. best to do a full empty and clean, and use a chopstick, or better still a cheap pipe-brush from the £ shop, to clear that tube (about 1/2 inch diameter, or maybe less.)
Hoover... | Answered on Apr 24, 2017
Hoover HCA390K Bottom Freezer Refrigerator Logo
11 questions posted
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Refrigerators
Most Popular Question
fridge freezer not getting cold freezing
  • Refrigerators
