20 Most Recent Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL USB 9600X2400 6.0IPM * 3747B002 Questions & Answers
hi. try to pull out the print head and clean the contact in the rear side . and reinstall it. if problem persist print head may be damaged
Canon PIXMA... | Answered on Mar 24, 2016
Try running it through its cleaning cycle a couple of times and then replace the cartridge.
Canon PIXMA... | Answered on Jan 15, 2016
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mp-series/pixma-mp560/!ut/p/z1/hZBPU4MwEMU_iweOsDtgsXhLqR1wQKfVqTEXB5wAUUgyIRX10xu1F__Vve2-35t9u8CAApPVk2grK5SsetffsviuXGfzLE-xuFyFZ0jK621RRnmEmxhu_gOYk_GPIgjnH8ABv0sQmjItW2C6sp0vZKOAaiOk5WYEOu60Vsa6-eMDt_5eADpof-RGcIdo8TxU_qBnMbq87OtG3CQnSOJlnCUXC8zXsx_AdnHsgGSZRuHqPfUeOHxU26v6839E1tHcpTe84YabYGfcuLNWj6ceejhNU9Aq1fY8uFeBkB7-ZurUaIF-Z0EP9LUgzVXus_plIkdvNVbgyQ!!/dz/d5/L2dBISEvZ0FBIS9nQSEh/
Download Windows 7 driver and right click on installion icon and run compatability select windows 7.
Right click and select run as administrator.
This will solve the problem of installation on Windows 10
Canon PIXMA... | Answered on Nov 13, 2015
Canon printer class action suit
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Canon PIXMA... | Answered on Jun 24, 2015
FIRST OF ALL I WILL ADVISE YOU TO REMOVE OR DELETE ALL OF YOUR PRINTER DRIVERS FROM YOU COMPU DO THIS AFTER YOU UNPLUG AND DISCONNECT ALL THE CABLES OUT OF FROM THE BACK OF YOUR PRINTER AND COMP AFTER YOU DO THIS GO TO CANNON WEBSIDE>SUPPORT > DRIVERS ENTER YOUR PRINTER MODEL# COMPU INF ETC DOWNLOAD AND INSTALL DRIVERS , THEN RECONNECT ALL CABLES BACK AND FOLLOW INSTRUCTIONS AND YOUR PRINTER SHOULD WORK BACK.
Canon PIXMA... | Answered on Sep 29, 2014
Leave the cover open, turn off, before it off, hold the reset & Start (color) until it completely off, then turn it back on. it works for me, good luck folks
Canon PIXMA... | Answered on Aug 27, 2014
Replacement of the printer head is recommended but some times its not worth the printer value.
Canon PIXMA... | Answered on Jul 20, 2014
Is this cartridge a Canon cartridge or a generic aftermarket one? The aftermarket ones tend to fail a lot more even though they might be new. Try another cartridge to see if that helps. I feel your pain because I also use aftermarket cartridges because they're 1/4 of the price, but this is a common occurence. Let me know if that helps.
Canon PIXMA... | Answered on Apr 24, 2014
Go To Below official Canon Printer Page For Your problem,
http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Canon PIXMA... | Answered on Apr 01, 2014
Try this. Disconnect printer from computer
2. re- connect after a minute.
3. from tools menu, clean cartridge.
4. now allign cartridges from the same tool menu.
5. complete allignment process as directed.
6.now try test print.
Canon PIXMA... | Answered on Dec 22, 2013
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
if its driver related
Click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope it helps
Canon PIXMA... | Answered on Oct 23, 2012
make sure all leads connecting to your printer have dust free secure seating
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope this helps
Canon PIXMA... | Answered on Jul 28, 2012
thats not a real number for any canon service unit. it is spam
Canon Office... | Answered 3 hours ago
Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL USB 9600X2400 6.0IPM * 3747B002 Logo
Popular Tags
40 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon pixma 560 printer scanner
  • Office Equipment & Supplies
