20 Most Recent Canon Ir 3300 Black & White Copier Questions & Answers
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Canon Ir 3300... | Answered on Jul 26, 2019
http://www.copytechnet.com/forums/canon/4517-how-reset-copy-counter-ir-series.html
Canon Ir 3300... | Answered on May 08, 2019
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Canon Ir 3300... | Answered on Apr 06, 2019
Have you selected the A4 setting in the software under "preferences"?
Canon Ir 3300... | Answered on Mar 05, 2019
Hi. In the drum unit is located a cleaning blade, maybe is defective and needs to be replaced or change the whole drum unit to solve the problem.
Canon Ir 3300... | Answered on Jan 14, 2019
https://www.youtube.com/watch?v=saIFL-1UDvg
Canon Ir 3300... | Answered on Aug 11, 2018
The problem is in temperature of a fixing film.Try to clean the heater,put on the grease...If ther's still a problem,replace the heater
Canon Ir 3300... | Answered on Apr 13, 2018
on a server
Make sure the networked printer is turned on and connect to the Internet using an Ethernet cable.
Click "Start" on the server computer and click the "Printers and Faxes" icon.
Click "Add a Printer" on the left side of the window.
Choose "A Network Printer" from the pop-up window, and click "Next."
Type in the exact location or Internet Protocol (IP) address of the networked printer, and then click "Next."
Select the printer manufacturer and model from the list of driver options. Click "Finish" to complete the printer installation process.
on a home network
Navigate to the Control Panel and click on "Printers and Other Hardware."
Click the printer you want to share in the Printers and Faxes folder. Click on "Share this Printer" in the Tasks Pane or right-click on the printer and select "Properties.
Open the Sharing tab and click on "Share this Printer." Enter the name of the shared printer and click "OK."
Use the shared printer with any computer on the network by navigating to Control Panel > Printer and Other Hardware.
Click "Add a Printer" and browse for the network printer you just shared.
Connect the Printer Directly to the Network.
Plug the printer directly into the network hub or router.
Follow the instructions for setting up the printer for networking provided by the printer manufacturer.
Click "Add a Printer" and browse for the network printer.
hope this helps
Canon Ir 3300... | Answered on Dec 27, 2017
1. Glass could be dirty, smoggy
2. Lid that is not closing on the one side.
3. Scanner unit faulty.
Canon Ir 3300... | Answered on Sep 30, 2017
canon ir2200 E000805-002
E805
The clock signal is absent for 5 sec or more after the fan drive signal has
been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The
Action
1. Foreign matter
Is there foreign matter that prevents the rotation of the fan?
YES: Remove the foreign matter.
2. Wiring, Connector
Are the wiring and connector of the fan normal?
Developing fan (FM1): DC controller PCB (J302B)
Fixing fan (FM2): DC controller PCB (J308B)
Curl reducing fan (FM4): DC controller PCB (J311B)
Curl reducing fan (FM5): DC controller PCB (J311B)
Electrical unit fan (FM3): main controller PCB (J1028)
NO: Correct the wiring and the connection.
3. Fan, DC controller PCB
Try replacing the fan. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Canon Ir 3300... | Answered on Sep 14, 2017
The heatsink roller or in the worst case scenario whole heatsink assembly needs to be replaced most probably.
Canon Ir 3300... | Answered on Apr 06, 2017
Canon Ir 3300 Black & White Copier Logo
128 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
when printing id cards picture blurre
  • Office Equipment & Supplies
