20 Most Recent Hoover S3614 Vacuum Questions & Answers
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Hoover S3614... | Answered on Dec 02, 2008
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Hoover S3614... | Answered on Feb 13, 2008
I don't know what is your experience with wire's soldering, but you should remove the insulation from the damaged wire and solder the disconnected edges. Then wrap an insulation band on the repaired wire first and then on all the other wires. Be aware power cable is disconnected !!!! If you can't do it by yourself - repair cost for it should be very cheap. Good luck !!
Hoover S3614... | Answered on Jun 28, 2006
If you can by pass the switch see if the machine runs that way. If it works by bypassing the switch then the switch needs replacing.
Hoover Vacuums | Answered 26 minutes ago
Many Vax vacuum cleaner trouble-shooting and maintenance tips are available here: https://support.vax.co.uk/ . The VRS116 support page is https://support.vax.co.uk/u90-ma-re-powerforce-version?___store=support_portal_uk .
The user guide for the VRS116 applies to several models. You can find a link to this manual from the above Vax support page link by searching on the VRS115: https://support.vax.co.uk/u91-ma-be-powerforce-version . The link to the manual is just above the Maintenance section. The direct link to the manual is http://library.vax.co.uk/resource/1387/vrs115/user-guide.pdf .
I hope this helps.
Hoover Vacuums | Answered Yesterday
Most common fault with vacuum cleaners is an internal break in the power cord. This is followed by switch problems and then the internal thermal fuse or breaker.
The answer is to partially dismantle and check the circuit with a multimeter.
Power cords usually fail close to either end so taking a chance and shortening it by a foot or two and fitting a new plug could pay off.
Hoover Vacuums | Answered 3 days ago
Check the hose where it attaches inside the machine. They often get cracks which leak when using the tool.
Hoover Vacuums | Answered on Aug 11, 2018
Any vacuum cleaner repair and sales shop would be able to supply the parts.
Hoover Vacuums | Answered on Aug 03, 2018
There is a hubcap assembly on the outside of each rear wheel that must be removed. Under the hubcap you will need to remove the e clip from the shaft to allow the wheel to slide off.
Hoover Vacuums | Answered on Jul 24, 2018
Hoover S3614 Vacuum Logo
5 questions posted
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
hoover vacuum
  • Vacuums
