Crosley CA15WYR Thru-Wall/Window Air Conditioner
Problems with Crosley CA15WYR Thru-Wall/Window Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Crosley CA15WYR Thru-Wall/Window Air...
Troubleshooting and Support
Solved Problems for Crosley CA15WYR Thru-Wall/Window Air Conditioner RSS Feed
View More Results for Crosley CA15WYR Thru-Wall/Window Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Crosley CA15WYR Thru-Wall/Window Air Conditioner RSS Feed
Answer
display nor remote will work to change temp. on air conditioner stuck on 97 degrees
Find a Manual
Crosley CA15WYR Thru-Wall/Window Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
Tips & How To Guides for the Crosley CA15WYR Thru-Wall/Window Air Conditioner
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
A Tip to Remember when Electrical troubleshooting
If you're troubleshooting HVAC electrical problems 230 volt single phase ac The Common wire or circuit on an A/C or heat pump never has a run... written by blvl777
Air Conditioner Ice Air Conditioner Problem
If you are experiencing the problems caused when your air conditioner becomes a solid block of ice then you need to figure out the real reason why it... written by heatman101
Air Electronic Cleaner - Electronic Whole House Air Cleaner
An electronic air cleaner can improve the indoor air quality as well as the performance of your heating and air conditioning system. That?s why many... written by heatman101
Central Air Conditioning or Window Air Conditioner
Many people look into installing air conditioning in their home every year. There are many options to consider when it comes time to make that... written by heatman101
Any time you disconnect any wires from anything.
Any time you diconnect any wires from anything always mark the wires with a piece of masking tape and write where you removed it from, especially if... written by blvl777
How to store you air conditioner for the winter?
Make sure that you tip the A/C unit to remove water that has condensed in it. If water is left in the system over the winter/spring, it can rust out... written by perrault
how to make your heat pump more efficent
you should first change your filter ,this type of unit relies on good air flowFind a HVAC supply house in your area (they all say there not open to... written by bwood348
Checking out a Air Conditioner Compressor and compressor problems
Checking out a air conditioner compressor and compressor problems FIRST DISCONNECT ALL ELECTRICAL POWER Ohm the windings C to R = example 1.2 C to S =... written by blvl777
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Crosley CA15WYR Thru-Wall/Window Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Ratings for the
Find a Warranty
Specifications for Crosley CA15WYR Thru-Wall/Window Air Conditioner
Other Features
Filter
Reusable
Key Features
Type
Thru-Wall/Window
Cooling Capacity
14500 BTU/hr
Energy Efficiency Rating
9.7 EER
Electrical Requirements
Voltage
115
Dimensions
Depth
25.88 in.
Height
16 in.
Width
25.38 in.
Crosley Contact Information
Main support number(336) 761-1212
Support FAX(336) 721-0685
Describe your problem:
Top Air Conditioner Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
