A) FOLLOWING Anti-Static Precautions?If you, or someone who had the board before you didn't, you can use it for a Frisbee now.(WOW! Look at that thing GO!)B) Processor installed with Heatsink, and fan hooked up; and Ram Memory installed -> ONLY; you should get BIOS Beep Codes, and maybe Error Codes; plus the BIOS Setup screen.(Hooked to VGA monitor. No AGP graphics card used)No?FrisbeeC) Look at the Electrolytic Capacitors on the motherboard.(Radial Aluminum Electrolytic Capacitors to be exact)http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1284612http://capacitorlab.com/visible-failures/index.htmhttp://www.youtube.com/watch?v=Lut7MX5Dd_Ahttp://en.wikipedia.org/wiki/Capacitor_plagueCan they be replaced? Yes, the Capacitor Plague has been around for a LONG time, and is still affecting us today.Need guidance in replacing? Post back in a Comment.http://www.youtube.com/watch?v=YCSNWi3UHf4http://www.hardwaresecrets.com/article/595http://www.hardwaresecrets.com/article/616http://www.mouser.com/Passive-Components/Aluminum-Electrolytic-Capacitors/_/N-75hqt?Keyword=Electrolytic+Capacitors&FS=TrueYou click IN the fields needed. Leave alone;1) Manufacturer: The one's presented are of Excellent quality.2) Tolerance:3) Product: The capacitor examples that will be shown, ARE of computer grade quality.4) Operating Temperature Range:Fields you NEED are the values of the capacitor, and style;1) Capacitance: Look for -> uf ratings. uf = MicrofaradCapacitors on a personal computer's motherboard; are rated in Microfarads, ( uF), NOT Picofarads. (pF)2) Voltage3) Termination Style: -> Radial. BOTH leads come out of the bottom,http://en.wikipedia.org/wiki/Electrolytic_capacitor(Click on the second photo down on the right)When you have clicked in each field, and clicked on the values, and style; then go to the left, or right side; underneath, and click on -Apply Filters.Let's use a 4.7uF / 16 Volt / Radial electrolytic capacitor for an example,http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/_/N-75hqt?P=1z0wrjcZ1z0x565Z1z0z7l5&Keyword=Electrolytic+Capacitors&FS=TrueScroll down.Look under -> Dimensions - to get the physical size you need.D) Power Supply:Whip out your multimeter, and with the Function knob set to DC Voltage, check the 3 main voltage power rails.(If just a symbol, the symbol is a dotted line over a solid line)Check at the 20-pin ATX main power cable connector. I use a straightened out paperclip, and insert down into the back of the 20-pin ATX main power cable's connector.The BACK is where the wires go in.The straightened out paperclip is inserted down into the socket hole, in the Back of the connector; and slides past the insulation of that wire. It MUST touch a metal terminal at the end of the wire.Every wire going down into that ATX main power cable's connector; ends in a female Molex metal terminal.Orange wires are 3.3 Volts.Red wires are 5 Volts.Yellow wires are 12 Volts.Black wires are Ground wires.ALL Orange wires end in ONE central pint in the Power Supply.This is the 3.3 Volt power rail.You can test ANY Orange wire, and test the entire 3.3 Volt power rail.Same with the Red 5 Volt wires, and Yellow 12 Volt wires.Pick one to test.Paperclip in Positive socket hole, in 20-pin ATX main power cable's connector.Plus paperclip in ANY Black wire socket hole.3.3 Volt, 5 Volt, and 12 Volt wires are POSITIVE wires.Positive (Red) probe lead of multimeter touches Orange, OR Red, Or Yellow wire - paperclip.Negative (Black) probe lead of multimeter touches Black wire paperclip.Worried about shock?Naa.The dangerous voltage is contained in the case of the Power Supply.100 to 240 Volts AC.The Power Supply converts this AC voltage into the low DC Voltages stated above.In comparison two D cell flashlight batteries produce 3 Volts DC.NOT saying there may not be a spark!Connect a wire to a flashlight battery, and touch it to the bulb, and there is gonna be a spark. Just the way electricity works.This is why I suggest for those who are new at this; to have the Power Supply unplugged from power; and insert two straightened out paperclips, in the socket holes of the ATX main power cable's connector.Then (Making sure they don't touch each other), plug the Power Supply into power, and touch the paperclips with the probe leads of the multimeter.Tested 3.3 Volt power rail? (Orange wire)Then unplug the Power Supply from power, and move the paperclip over to a Red wire socket hole.Test for 5 Volts.Same again for the 12 Volt power rail. (Yellow wire)Or use a KNOWN to be good, Compatible power supply; for a test unit. Perhaps there is a working computer you can borrow one from.For additional questions please post in a Comment.Regards,joecoolvette[Are you sure the Ram Memory is plugged in tightly? CANNOT just visually inspect. Remove, and reinstall to be SURE.Are you sure the Ram Memory is the correct Frequency Rate?('Speed')Ram Memory typically operates at HALF of the Processor's Front Side Bus. (FSB) ]
Hmmm, one beep is good! lol! Means P.O.S.T. is good.http://www.newegg.com/product/product.aspx?Item=N82E16813186029I see we're working with an AMD processor, and a Socket 462 (Socket A), motherboard.Let's look at some basic installation problems for that motherboard, and see if any fit;1) Since it is an AMD processor motherboard, you have to be SURE that Thermal Paste has been applied PROPERLY, and applied.http://www.hardwaresecrets.com/article/274An AMD processor runs hot, for the models that fit that motherboard.If no Thermal Paste has been applied, the AMD processor could have burned up.2) Anti-Static Precautions:I know, I know. But you would be surprised with those of us, who do not know what Anti-Static Precautions are; and work on computers.(Hmmm, wonder why it doesn't work? Must be a bad motherboard)3) Mounting to the Support Plate.The Support Plate can be a separate metal plate; or is part of the computer case.Mounting of the motherboard to Support Plate can be done with plastic Spacers; or metal Standoff's.(Standoff. Shapes vary a little, but basically; 3/8ths to 1/2 inch long, hex shaped, threaded shaft on one end; and a threaded hole on the other end)If a Standoff is NOT mounted to a motherboard mounting hole; and is just sitting out there on the Support Plate; it can touch exposed solder joints on the bottom of the motherboard, and cause a Short Circuit.MOST of the time if the 'offending' Standoff is removed; or placed where it should be, (Motherboard mounting hole), then the motherboard, etc may be OK.4) Power Supply:If the Power Supply was on it's last leg, this may be the 'straw that broke the camel's back'. Power Supply went to the Power Supply graveyard in the sky.If the Power Supply does not have enough power (Wattage, and Amp's), then you would also see the problem you stated.New Power Supply, or old? What is the manufacturer, and model number?Post back in a Comment.What AMD Socket 462 (Socket A) processor did you install?What Ram Memory?How many optical drives? (CD/DVD drive)How many fans?Post back in a Comment.Regards,joecoolvette
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
some boards are out of OEM PCs like gateways or the like
others were sold as DIY from foxconn direct sales.
did you lose the PC case?
or buy just a mobo , raw?
front panel pinouts you meant but failed to say just what:?
foxconn (channel) went dead. 2012
the maunuls where there, then, and now all gone. they are gone.
all is gone but the echo, (waybackmachine)
old
Intel P55 / H57 chipset
age ,2009, and lost manuals, are are not, lost 2012 year when the went dead.
no can find, me....
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
is that not out of and HP.com PC?
Joshua-H61-uATX (Foxconn2ADA)
sp#670960
hp says used in over 200 produces by them
https://partsurfer.hp.com/Search.aspx?searchText=670960-001
step one find PC full model number not told
then at HP>com
click support
the manual is there.
see all hp service tag types here for 2 decades
https://www.pcdied.com/TAG-jive/tag.html
the top of your mobo has this tag
https://www.pcdied.com/MoBo/hpz210.JPG
and if there the SP# tells what it is.
foxconn make mobo for many oEM PCs. this is a fact
and the top sticker labels matter only.
see more here, for foxconn (now to tell what you have)
https://www.pcdied.com/foxconn.html
DON'T OR SAY WHY YOU MUST?
99.9^% DON'T
OR BRICK LIKE MILLIONS HAVE NOW.
today is foxconn day;. and they went EOL , DYI in 2019
no PC told so is a vacuum of answers.
94v-0 is PCB flame proof spec, certs.e253117, is outside USA, electrical safety certs, both uselessthen land on just ML.,useless too.the mobo I bet has a tag like these, learn to post real sticker tag labels only, not certs painted on the mobo we can not see.andWhat is N15235? (is and electric safety spec #)Often the marking N15235 is mistakenly deemed to be the model number of a mainboard or graphics card, but it's just Foxconn's ACA supplier code number which signifies that the product may be legally sold in Australia.
Tean ml1 (94v-0)
94v0 is useless input, it is PCB burn rate test certs.
what is a TEAN?
ELO TOUCH Main Board LL050 TEAN ML1???? 2003? year?
ELO is where to go not now dead foxconn (DIY) only is dead.
ELO Touch panel. The original touch screen was 996-0484-00, PT1503NT.
its not a PC it is only a monitor
what matters is the PC not told by you nor what OS you run.
or ask ELO for them.
here they are, had to do reverse look-ups on PCB.
https://www.elotouch.com/support/downloads#/
that is no good this number94V-0 is the PCB burn rate proofing code.(checkmark)E253117 is electrical safety rating,outside USA.so none of those are useful to you.the top side labels are the ones to read and tell.photo them and post it? FOXCONN ENDED SUPPORT 2019 FOR THEIR DIY BOARDSsee examples herehttps://www.pcdied.com/foxconn.html
N15235
that is not a model, it is electrical safety certification code. useless
lost your PC casings? no PC maker names nor model told
bought a raw mobo dead? from goons on amazon. rip offs.
they sell $5 used mobo there for $100 to noobs, then why not ask the goons for your manual, oops none.
translated by Alan Turing.
Hello. I am looking for, the technical sheet for this card m? re: Foxconn ml 94v-0 e253117? 100% bogus model for sure.
your reading the wrong label.
No PC told why are you pretending it has no PC only the motherboard?????
asked 7 times here and 1 answer and all links dead now from 2010 to now.
googling for you see this. (not yours 1 of thousands)
DELL FOXCONN E253117 ML1-Y MOTHER BOARD
DELL contracted to :
FOXCONN
E253117 Elect safety coded
ML1-Y
MOTHER BOARD
94V-0 (burn rate safety PCB)
188021545A
PWB REV A00
P08D1Q9073IA00
MADE IN CHINA
SP# is HP model service part number
dell stickers show Cn_ china # or Dp;N dell part number and 3d bar code.
the key word there is DELL, it is a dell contract board
so you lost your DELL PC is that it??????????
those rear numbers are no good. use only top sticker numbers only
he HP tag is white with some a 3d bar code
and dells codes on the sticker
SP#nnnnnnnn is the right number, that works
that I tell you the real model of your Missing PC.
warning dell and hp both have mobo bottom stamped e253117
that is an electrical safety code not any kind of model at all
stop reading the bottom of the card for sure copper etched.
read the top stickers onlyh
dell sticker mobo
Optiplex 760
hp sticker
z210
learn to read the sticker tags not painted on words.
those are all real OEM service tags, just 2.
there are 12 other OEMs that foxconn makes mobo under contracts.
post photo of you mobo tags
or tell what PC it came out of and DID NOT/
N15235 this is no model
that number is for electrical safety certification only.
post the sticker numbers on the mobo tell the true model , all of them, see SP#nnnnnn that is HP mobo
did you buy a used MOBO off the internet,just the MOBO
and no PC??????? not told that
N15235 stamp in on all there mobo every one for decades.
it means zero to you or any tech on earth this CERT
i think it is a Asian code, for sure not here USA ours is UL or RU.
here is your answer
power on and hammer Del key (if not for HP or Dell)
the main BIOS page shows now , new coin cell is a must.
then click bios default settings that resets CMOS NVRAM.
the set time and dead
then set boot order , in BIOS.
no problem stated, just nebular CMOS reset.
Foxconn 15235 N15235< forgot to say N"? (looking wrong for sure) N15235 is electrical stamped SAFETY certification number, so is bogus. that number as in totally useless . https://www.foxconn.com/en-us/ no PC told no OS told (goal) or PC usage. no motherboard told. at all, zero nada zilch. do not read the painted numbers, only the white stickers matter seen below. YES alwayssee that PCMCP61 matters. above what is yours goodnot this ever. below, see? wrong choice below for Model it is not a model most of these boards were contract boards top HP or Delland are pulls that are sold at crazy high prices. to noobs.dont buy this junk. above is old P4 junk. relics.
