20 Most Recent Hoover U5018-900 Bagged Upright Vacuum Questions & Answers
Check the opening behind the floor brush for obstructions there.
Hoover U5018-900... | Answered on Nov 09, 2017
The owner's manual can be downloaded here (in red, "Download the Instruction Manual (PDF))
http://www.hoover.com/product.aspx?model=U5018900&ds=false
Instructions for replacing the belt are on page 9.
You can order the belt here:
http://www.hoover.com/shop/searchresults.aspx?itemid=221224
Or use the "Retail Locator" on the first site.. Just type in your zip code, and a store that carries Hoover and products near you will be shown.
Hoover U5018-900... | Answered on Oct 07, 2010
look on the bottum of the machine you should see 4 screws there should be arrows next to them remove them and pull the base plate off remove the old belt put the belt on the drive shaft then put the belt on the upper wheel it might be a little hard but just roll it on useing the wheel
Hoover U5018-900... | Answered on Jul 01, 2010
buy a new pipe they are cheap to buy.adrian,,,,
Hoover U5018-900... | Answered on Jun 26, 2010
hi in answer to your question regarding the belt driven roller/brush on bottom of vac ? the nswer is yes it still rotates when you are using the tools on connection to flex hose ie stair carpet or areas the vac will not enter one word of advice ! if you use the vac/tools to vac the car interior as i and others do ? then ensure that whilst vac is stood and the flex hose and tool are in use? suggest you stand the vac on a flat surface(not the tarmacdrive or any porouse surface) preferably a rubber mat? or board so the rollerbrush is not subject to damage or apt to pick up stone chips etc which will eventually damage the motor impellor hope this helps answer your question and understand the safety point i mentioned best wishes
Hoover U5018-900... | Answered on Oct 19, 2008
Can't find manual. Belt broke, replaced it now no suction. Have checked for clogs none found.
Hoover U5018-900... | Answered on Oct 06, 2008
Your roller brush is starting to fail. If you unscrew the ends, you will find a lot of hair wound around the stem. You probably have a warped plastic end the holds the bearing. This is my problem now.... I am looking for a new roller brush as I write this. I found one for $30. Good Luck.
Hoover U5018-900... | Answered on Aug 21, 2008
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40860&thid=810370
Really loud noise.
Posted by Theresa626 on July 20, 2008
The belt inside my Hoover broke and so we replaced it. But when we did, it now makes an extremely loud noise when turned on. We think it’s the roller to the vacuum because it doesn't make a noise when the roller is not in there. The roller sounds like its hitting something. However, we have pushed and pulled and done everything and all seems to be right. Everything is clicked in and the belt is on correctly and we've followed the manual. How can I fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that it is a bad brushroll and could need new bearings or a complete new brushroll depending on if id is metal word or plastic. Some brushrolls are rebuildable and some are not, you can check your owner’s manual to see if it is or is not; or it could be the start of a broken fan blade or bearing in the motor section. But that is the only thing that I can think of that might be wrong. Feel free to contact your local vacuum cleaner dealer in your area or you can also contact the Hoover website or cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Hoover U5018-900... | Answered on Jul 21, 2008
If you can by pass the switch see if the machine runs that way. If it works by bypassing the switch then the switch needs replacing.
Hoover Vacuums | Answered 3 days ago
Many Vax vacuum cleaner trouble-shooting and maintenance tips are available here: https://support.vax.co.uk/ . The VRS116 support page is https://support.vax.co.uk/u90-ma-re-powerforce-version?___store=support_portal_uk .
The user guide for the VRS116 applies to several models. You can find a link to this manual from the above Vax support page link by searching on the VRS115: https://support.vax.co.uk/u91-ma-be-powerforce-version . The link to the manual is just above the Maintenance section. The direct link to the manual is http://library.vax.co.uk/resource/1387/vrs115/user-guide.pdf .
I hope this helps.
Hoover Vacuums | Answered on Aug 13, 2018
Most common fault with vacuum cleaners is an internal break in the power cord. This is followed by switch problems and then the internal thermal fuse or breaker.
The answer is to partially dismantle and check the circuit with a multimeter.
Power cords usually fail close to either end so taking a chance and shortening it by a foot or two and fitting a new plug could pay off.
Hoover Vacuums | Answered on Aug 11, 2018
Hoover U5018-900 Bagged Upright Vacuum Logo
16 questions posted
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
vacuum roller making loud noise
  • Vacuums
