20 Most Recent
Hoover U5264-930 TurboPower Bagged Upright Vacuum Questions & Answers
Not picking dirt and small items, doesnt to be
make sure bag is empty and there isnt any cloggs in the hose or nozzle. If that is good, change the belt. these should be replaced every 6-12 months and when something gets caught in the brushroll
Won't work cleaning tools
There is a clog somewhere.
Most likely at any bends or where the hose enters the main body of the vac.
Make sure it's unplugged.
Romove the hose, stretch it out straight and see if you can see through it.
If there arer any hard piped bends try running a pipe cleaner through it to see where the blockage is.
Again, it's likely where the hose base meets the vac housing.
Needle nose pliers com in handy for pulling out string, hair, rig fibers pet fur etc.
Problem with wheels
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
My spin scrub does not suck up dirty water
When your Hoover spin scrub is not sucking up water, the most common problem is the clear round cap located on the suction nozzle is not closed. See pic. Also check the rubber cap on the dirty water tank.
How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Hoover SteamVac F5851 - solution dispenser and extractor running simultaneously.
If your Hoover SteamVac F5851 is simultaneously dispensing the cleaning solution and extracting it while you have the trigger depressed, there may be an issue with the unit's internal mechanism. Here are a few troubleshooting steps you can try:
1. Check the trigger mechanism: Make sure the trigger is not stuck or jammed in the depressed position. Gently press and release the trigger a few times to ensure it moves freely.
2. Inspect the solution dispenser: Examine the solution dispenser to see if there are any clogs or blockages that might be causing the simultaneous dispensing and extraction. Clean the dispenser thoroughly, removing any debris or obstructions.
3. Verify the solution flow setting: Ensure that the solution flow setting on the SteamVac is correctly adjusted. There should be a control or dial that allows you to adjust the amount of solution being dispensed. Make sure it is set to the desired level and not malfunctioning.
4. Check the suction nozzles: Inspect the suction nozzles and brushes to ensure they are securely attached and not damaged. If any parts appear loose or worn out, you may need to replace them.
5. Clean the unit: Give your SteamVac a thorough cleaning, both inside and out. Remove the recovery tank, rinse it, and make sure it is properly reattached. Clean the brushes and nozzles to remove any built-up dirt or debris that could be affecting the unit's performance.
If these steps don't resolve the issue, it's possible that there may be a more significant problem with the internal components of your SteamVac. In that case, you may need to contact Hoover customer support or take the unit to a professional repair service for further assistance.
Hoover vacuum UH72625v wiring upright Windtunnel
Look inside the wire crimps with the white and yellow wires for wire strands alongside the other wires (broken off of the power cord). If you see some, that's the neutral connection.
If you don't see any stray strands in either connector, you'll have to trace the wiring. First, check how many connections there are on the power switch. If there are only two (one should be connected to the black wire going to the power cord), the answer is not there, and you'll have to identify the wire that goes directly to the motor and the lamp socket (including any wires connected together).
If there are four terminals on the power switch, with black wires going to one pair of terminals and white or yellow wires going to the other pair, identify which black wire goes to the power cord connection. The white wire next to it goes to the connection you want.
How did you manage to pull the power cord out of the connectors? There's supposed to be some kind of clamp, knot, or other restraining means where the power cord goes into the vacuum cleaner to prevent this potentially dangerous situation. If that is broken or missing, get it repaired before using the vacuum cleaner.
