20 Most Recent HP DELL G849F INSPIRON 1545 MOTHERBOARD Questions & Answers
Need motherboard specs website
Okay.http://www.ebay.com/itm/DELL-INSPIRON-1545-GM45-Intel-Motherboard-G849F-0G849F-/300769480662?pt=LH_DefaultDomain_0&hash=item4607420fd6There are two views of the motherboard. By default when the link is clicked on, the Bottom view is the large main view.(In the two views shown, it is the view on the Left )Looking at the Bottom View;1) The Pink(?) square socket you see at the top is the Processor socket. (CPU - Central Processing Unit. Another term used is Microprocessor, or simply Processor)It is a Socket P mobile processor socket,http://en.wikipedia.org/wiki/Socket_P2) Processor?Dell gives you options, so it's hard to say what Intel processor is on your motherboard. The Intel GM45 mobile chipset, supports mobile processors that are Intel Core2 Duo, Intel Core2 Extreme, and Intel Celeron M.A 667MHz, or 800MHz, or 1066MHz FSB is supported.I have seen an Intel Core2 Duo, model T6400 offered, so I know it supports using a Socket P processor socket, uses a 1.00 to 1.250 voltage range (DC), and the Penyrn-M Core, and 45nm technology,http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Penryn.22.2C_.22Penryn-3M.22_.28standard-voltage.2C_45_nm.29Laptop disassembled the easiest way to find out, is to put an ESD wrist ********, connect it's alligator clip to a good ground source, and look at the Processor.GENTLY use an old credit card, to scrape off as much if the thermal paste as you can, then use Q-tips dipped in Isopropyl Alcohol.(Takes a bunch of alcohol soaked Q-tips)Look for the sSpec Number, and the Part Number. Then 'google' it.[CAUTION!!Isopropyl Alcohol is EXTREMELY FLAMMABLE!Use in a WELL ventilated area with NO sparks, or flames present!]Laptop together, functional, and internet ready, use CPU-Z from CPUID.com to find out.3) Below the pink Socket P processor socket is part of the motherboard chipset.The Northbridge chip. It is an Intel GM45 chipset, it is an SMD (Surface Mount Device), and uses a BGA surface mount,http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsetshttp://www.ebay.com/itm/NEW-1X-Intel-AC82GM45-QV08-ES-Chipset-With-Balls-2010-/221068892458?pt=LH_DefaultDomain_0&hash=item3378bb992aBGA surface mount. Ball Grid Array surface mount.View a BGA Rework Station in use, and learn in detail what a BGA surface mount is,http://www.ersa.com/art-ir-pl-650-346-1472.htmlScroll down, click on the red - Take a few minutes to view the IR 650 video demoThe Southbridge chip is an Intel 82801IMB, (ICH9-M)It's on the Top of the motherboard. [Chip and Chipset are slang terms for I.C. Integrated Circuit,http://en.wikipedia.org/wiki/Integrated_circuit(A Processor is an I.C.) ]The motherboard chipset is the Northbridge chip, and the Southbridge chip. (Does Not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)The Northbridge chip handles the Faster capabilities of a computer.The Processor, Ram Memory, and HIGH-speed graphics.AGP (Accelerated Graphics Port), and PCI-Express, are High-speed graphics.A graphics card using a PCI expansion slot, and Integrated graphics, is Not high-speed graphics.[Integrated Graphics used to be referred to as OnBoard Graphics.ON the motherBOARD. Easier to understand ]The Southbridge chip handles the Slower capabilities of a computer.1) Anything connected to the PCI bus.PCI expansion slots, or OnBoard Graphics.2) Anything connected to the IDE bus3) SATA bus4) USB bus5) Ethernet bus6) Audio (Sound)http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg[CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor, for short ]As you can see Serial Ports, Parallel Ports, Floppy Disk drive, the Keyboard, and Mouse, are connected to the Super I/O chipset.[I/O = Input/Output. Input and Output devices ]I do not know what Super I/O chipset is used.You may want to look through this chart, and see yours matches up with one of them, (They are probably too old, but gives you an idea of what to look for),http://web.archive.org/web/20070929033214/http://www.esupport.com/techsupport/award/superio.htmThere are Two Ram Memory slots. (Seen on bottom of motherboard)Maximum Amount for each Ram Memory slot is 4GigaByte.Maximum TOTAL Amount is 8GB.Uses DDR2 Sdram that is SO-DIMM.(Small Outline Dual Inline Memory Module)Smaller in size than desktop computer DIMM.Can use either DDR2 Sdram at 667MegaHertz, or 800MHz.(PC2-5300 and PC2-6400, respectively)Uses a 2.5 SATA harddrive.Continued in an added Comment.Regards,joecoolvette
9/2/2012 5:19:18 PM • HP DELL G849F... • Answered on Sep 02, 2012
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
2answers
I have installed 4G RAM, Is that the MAX supported or may upgrade to more ?
Memory Max Maximum supported = 8GB
2/17/2024 5:55:53 AM • HP Computers &... • Answered on Feb 17, 2024
3answers
I have an HP Pavillion533w that will not turn on when I press the power button.
Here are troubleshooting steps for when your computer won't start:
2/15/2024 7:54:52 PM • HP Computers &... • Answered on Feb 15, 2024
2answers
Why won't my HP tower computer turn on?
Here are some troubleshooting steps for when your computer won't turn on:
2/15/2024 7:54:39 PM • HP Computers &... • Answered on Feb 15, 2024
2answers
Hp probook 4440s keyboard light function key shotcut
To adjust the keyboard backlight on your HP ProBook 4440s, you typically use the "Fn" (function) key in combination with one of the function keys that has a symbol representing the keyboard backlight.
2/12/2024 8:56:21 PM • HP Computers &... • Answered on Feb 12, 2024
Look for the driver for my Pc media center M7000 product M7682fr system number RF893AA ?
Visit the HP Support Website: Go to the official HP support website at HP Customer Support. Enter Your Product Details: Enter the product name "Media Center M7000" and locate the specific model or product number. In your case, you've provided the system number RF893AA, which is also known as the product number. Locate Drivers and Downloads: Once you've identified your product, navigate to the "Software, Drivers, and Firmware" section. Choose Your Operating System: Select your operating system (e.g., Windows) and its version (e.g., Windows 7, 8, 10). Find and Download Drivers: Look for the drivers related to your PC's components, such as graphics, audio, network, etc. Download the required drivers to your computer. Install the Drivers: After downloading the drivers, run the installation files and follow the on-screen instructions to install them. Restart Your PC: After the installation is complete, restart your PC to apply the changes. If you face difficulties finding the specific drivers for your model or if your PC is quite old and HP no longer provides drivers for the chosen operating system, you may need to consider using default drivers that come with the operating system or upgrading your operating system.
2/12/2024 8:56:17 PM • HP Computers &... • Answered on Feb 12, 2024
2answers
Battery pluged in but not charging hp 620
This video has some troubleshooting steps you can try:
2/10/2024 8:10:17 PM • HP Computers &... • Answered on Feb 10, 2024
4answers
How do i download a whatsapp on a laptop
Although whatsapp is a phone messenger, some sites offer software to install on a PC or laptop. On your own risk, you could try this site for that: Download Install Web WhatsApp on Desktop PC or Laptop with without...
1/28/2024 5:04:17 AM • HP Computers &... • Answered on Jan 28, 2024
HP DELL G849F INSPIRON 1545 MOTHERBOARD Logo
3 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
need motherboard specs website
  • Computers & Internet
