20 Most Recent
Bushnell Powerview - Compact 10 x 25 binocular with a 10X magnification. Questions & Answers
Double vision
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows:
1. Focus on a distant object.
2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view.
Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields.
Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
8/4/2007 6:27:53 PM •
Bushnell...
Answered
on Aug 04, 2007
Eyepiece assembly bushnell telescope
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
