20 Most Recent
MicroBoards CFD-USB-15 1 Read,15-Port USB Flash Drive Duplicator - Questions & Answers
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details hope it helps
NEED MANUAL
What is the model of your MicroBoards drive?
Microboards G4 sure thing program doesnt always open
The basic troubleshooting steps for a balky program like this would be to reset preferences, if that does not work, then simply uninstall the program and then reinstall it. Please note that this action may delete any presets that you had set up...
CD does'nt slide anymore inside the printer to be printed at the second step, after going down at first
Either the sensor and/or the laser lens inside the tray are dirty, a common fault printers)or you are not aligning the disk properly when placing in the tray. You can try using a CD\DVD cleaning disk and a can of compressed air to blow out dust. If this fails uninstall the printer's drivers and software and reinstall everything from the beginning. If that fails return for repairs. NEVER use stick on disc labels, only use write on discs
Dvd prm 316 error 1105
System error code 1105 means "Tape could not be partitioned." This error code may also display as "ERROR_PARTITION_FAILURE" or as the value 0x451.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
