Troubleshooting & Support
Hot Topics:
- brushes won...
- brushes won...
- manual
- steam vac
- brushes
- motor
- steam vac brush
- parts
- clean water...
- brush
- switch
- detergent tank
- water
- attach hose
- not water
- floor
- suction
- hand vac
- turn
- clean
- steam
- dual
- steam vac leaks
- deluxe
- sucking water
- water...
- clean turbine
- water release
- not sucking...
- sucking
- View All »
Problems & Solutions
Brush assembly will not spin at all.
The turbine is bad, that is what drives the brush roll. You either replace it, sometimes you can take the turbine apart and clean it, alot...
lost manual
Couldn't find one thru Hoover, so it may not be available. On the metal tag where the model is, there is a number for Hoover, you might...
Hoover SteamVac
My Hoover Steamvac won't puo=ll out the water when I try to cleean the carpet. What do I need to do? K758@aol.com
Where can I get the valve
Try this site: http://www.daltonvacuum.com/scripts/ProdList.asp?idCategory=258&nameCate=Hoover&nameSubCate=Steam%20Vac%20Parts
I have a Hoover SteamVac Deluxe
If yours has separate tanks for the solution and water, it is a pressure regulator switch. It happened on my mine and I replaced it. 3...
Hoover Steam Vac repair
Hi... First and foremost, I'd urge you to borrow or rent another immediately, vaccuum that excess moisture out before our house...
THE BRUSHES DO NOT TURN ANYMORE IS THERE A BAND
There is no belt on this machine. The part that makes the brushes turn is called the Turbine. Here is the part you need Hoover SteamVac...
brushes won't spin
The brushes are turned by belt and/or motor.
replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Hoover SteamVac V2 - won't release water
sorry this is so late. the problem might be that the tubes are clogged. after each use most people just put the machine away. in most cases...
Plastic parts breaking
none ! in most cases Hoover is the best. Whatever you do don't buy Bissel
It is not sucking up all the water
I have this problem with my Hoover SteamVac V2 occassionally. I usually find it is caused by one of three things. The dirty water tank is...
How do I replace the solution tank valve?
Mine has done the same thing twice. I don't think you can store any unused solution in the container because it eats away at the rubber...
Hoover SteamVac V2 6-Brush WidePath Brushes...
I found sometimes you can't order some parts directly from Hoover for some products but you can get them thru the Sears parts ordering...
I can't find the manual for my turbo steamvac...
go www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.comfinally you must go to Hoover.com and downloadGod bless you
See all Hoover F7205900 SteamVac V2 Wet/Dry Vacuum Solutions
Unsolved Problems
Where can I find Manuel Instruction for Hoover
Where can I find Manuel Instruction for Hoover F7205
cleaner doesn't want to **** up the water. ...
cleaner doesn't want to **** up the water. Any suggestions?
Hoover F7458-900 SteamVac The brushes quit
Hoover F7458-900 SteamVac The brushes quit turning. Why?
I already bought the replacement valves for my
I already bought the replacement valves for my Hoover Steam Vac 2 but neither the seller nor Hoover Customer Care could...
The steam cleaner dumps water.
The steam cleaner dumps water. We ordered new valves. Did the repair and it still dumps the water. But when the...
rinse water dispenses but shampoo does not...
chekced hoses and metering pad all are clear and switch obviously is working
Manuals & Guides
TopDo you have a manual for Hoover F7205900 SteamVac V2 Wet/Dry Vacuum? - Upload it to FixYa!
Upload a manual for Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Specifications
TopKey Feature
Full Product Name:Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Dirt Capture:Wet/Dry
Tank / Bag Capacity:1 Gallons
Motor
Amperage:12 Amp.
Tools
Number of Tools:1
Convenience
Features:Rotating brushes
Features:Edge Cleaning
Cord reach:27 ft.
Hose Reach:8 ft.
Warranty
Warranty:1 Year Parts and Labor
What's your problem?
Fix-O-Meter
3,072
3,072 people have viewed this product
- 39 people asked about this product.
- 14 people found solutions for this product.
- 1 person has added this product.
Euro-Pro Shark...
How to Find...
How To Replace...
