Hoover S3755 WindTunnel Bagless Canister Vacuum
Problems with Hoover S3755 WindTunnel Bagless Canister Vacuum?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Hoover S3755 WindTunnel Bagless Canister...
Troubleshooting and Support
Solved Problems for Hoover S3755 WindTunnel Bagless Canister Vacuum RSS Feed
View More Results for Hoover S3755 WindTunnel Bagless Canister Vacuum
Questions and Unsolved Support Problems
Unsolved Problems for Hoover S3755 WindTunnel Bagless Canister Vacuum RSS Feed
Answer
My Hoover Windtunnel has problems with suction control. It only works in the first and second stage... (More)
Answer
Power head only works if held at certain angle. -- interesting that the same problem should manifest... (More)
Answer
powerhead stopped working. Was working fine, removed the powerhead to use just the pole. When... (More)
Answer
is model # s3765-040 the same as the s3755 ? has the s3765-040replaced the s3755 ? where can i... (More)
Answer
Red HEPA light is on as soon as I plug in vacuum, before I even start the suction motor. All... (More)
Answer
Drive belt for power head beater brush on Hoover S3755 keeps jumping off drive motor shaft when... (More)
Answer
I can't get the head off. I have a clog in there and don't know how to get the head off the vac.... (More)
Find a Manual
Hoover S3755 WindTunnel Bagless Canister Vacuum Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Hoover S3755 WindTunnel Bagless Canister Vacuum
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
re use vacume bag trick
take out your vac bag and if you have no others u can snip off the bottom where it is folded over dump out the junk flaten out the bag on the table... written by roman1021
Rainbow Vacuum Cleaner
Make sure to rinse or replace the Hepa Filter on your Rainbow Vac. Failure to do so can, and will more than likely, result in burning up the motor!... written by #1 Taper
To remove transmission fluid.
If over fill transmission , you can take a turkey baster ,cut a pencil size hole in the bulb, add on a peice of 3/8 tubing about 3 ft long to the... written by canddplumb
Kenmore crossover bags
Did you know? Kenmorre 50567 bags also are directly compatible with the Sharp PU-2 bags, Panasonic U-2 bags, and Miele type Z written by renevacdoc
Useful Tips for Sebo's X1 Bagged upright vacuum.
Own a Sebo Automatic X1 Bagged upright or perhaps a Windsor-Sensor model? Here are a few tips to get more out of your machine.  When it comes to... written by ukvacfan
SMELLY KIRBY BAG???? HERE'S WHAT TO DO!!!!
I have written a guide to help with the cloth bag odor problem. View it simply by clicking this link....YOU'LL BE AMAZED AT HOW EASY IT IS!!... written by b0sslady2001
IS YOUR KIRBY BROKEN?****FIX IT YOURSELF WITH MY GUIDES!!!!
I have written a troubleshooting guide for diagnosing and fixing your G series Kirby. I hope you find it helpful!!! Click the link to view...... written by b0sslady2001
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter... written by ukvacfan
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Hoover S3755 WindTunnel Bagless Canister Vacuum
Nationwide | 8778228227 | Website
When you browse our large selection by vacuum cle... Read More
Featured Listing
Nationwide | 502-348-4900 | Website
Authorized Dyson and Miele Service center. Work on ... Read More
Featured Listing
Nationwide | 7403742373
WE SERVICE, REBUILD, CLEAN AND REPAIR KIRBY, RAI... Read More
Ratings for the
Find a Warranty
Specifications for Hoover S3755 WindTunnel Bagless Canister Vacuum
Key Feature
Design
Canister
Dirt Capture
Container
Motor
Consumed Power
1380 Watt
Speeds
Variable Speed
Voltage
110 - 120 V AC
Amperage
12 Amp.
Filtration
Filtration Technology
HEPA
Tools
Number of Tools
Cleaning Path
15 in.
Convenience
Features
Edge Cleaning · Cord Rewind · Telescopic Wand · Handle Controls
Cord reach
22 ft.
Hose Reach
6 ft.
Special Features
Filtration Efficiency
.3 µ
Weight
Weight
13 lb.
Warranty
Warranty
1 Year Parts and Labor
Hoover Contact Information
Main support number1-800-944-9200
Describe your problem:
Top Vacuum Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
