FixYa.com
Unitech PT630 Portable Terminal
All Products > Unitech > Barcode Scanners
Problems with Unitech PT630 Portable Terminal?
Search inside Unitech PT630 Portable Terminal Knowledgebase
Troubleshooting and Support
Solved Problems for Unitech PT630 Portable Terminal RSS Feed Post a New Problem
unitech pt630 scanner
I have all my inventory in the scanner and now it is stuck in kermit server mode..What do I do?Please help.... Thank...
3 Solutions
External Program
I need a simple (?) program when executed from the pc it will copy/move the collection file to a designated location. ...
2 Solutions
Unitech PT630 files
I am trying to replicate all programs from one PT630D to a newer unit, with no luck. I've used both kermit and PTCom,...
1 Solution
Problems with BHT scanner
when downloading data to BHT (new lookup) it starts to transfer some information and then stops, and 'File transfer,...
1 Solution
change region code on my apple mac
I have bought a DVD from Amazon and can't play it because I can't change the regio code on my computer - how do you do...
1 Solution
Optical Drive not working.
Hi! I use a Toshiba Tecra M5 notebook & it has MATSHITA DV RAM optical drive. This device is not working & the...
1 Solution
DS6708 symbol scanner freezes keyboard
Hi I was using this scanner for a few hours but we changed a few settings (by scanning barcodes from the manual). The...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Unitech PT630 Portable Terminal RSS Feed Post a New Problem
PT630D - Turning beep down or off
I do not have a manual for PT630D. How do I turn the beep sound down or off? Thanks.
Post a Solution
PT630 Problem reading with the Sun
I have a portable PT630 and when we use it ounder Sun of half day we have a problem for reading the barcode of our...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypePortable Terminal
InterfaceRS-232
ConnectivityCordless · Wired
Optical
Light Sourcevisible laser diode (VLD)
Scan Rate36 Scans per second
Pitch Angle55 · 48
Skew angle65
Sensor Type2D CCD
Technical Features
Special FeaturesLCD Display · LCD Display, Keypad · Positive Led user feedback, LCD Display, Keypad · LCD Display, Keypad, Upgradable Flash Memory · Positive Led user feedback, LCD Display, Keypad, Upgradable Flash Memory · Positive Beeper user feedback, LCD Display, Keypad, Upgradable Flash Memory
CompatibilityPC
Decode CapabilityEAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Chinese Postal · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Interleaved 2 of 5, UCC EAN 128, Chinese Postal · EAN-8, EAN-13, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, ISBT 128, Code 128, CODABAR, Interleaved 2 of 5, Chinese Postal · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Interleaved 2 of 5, Chinese Postal · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, ISBT 128, Code 128, CODABAR, Interleaved 2 of 5, Chinese Postal
Environment protectionHumidity: 5% - 95% non condensing · IP 54 (Water and Dust Resistent), Humidity: 5% - 95% non condensing
Battery
BatteryRechargeable, Lithium-ion · Lithium-ion
Dimensions
Depth1.38 in.
Height6.6 in.
Width.54 in.
Weight0.54 lb.
Warranty
Warranty1 Year
Supported Models
101000-0550, pt630-0c00b, pt6302c00b, pt630-3c00b, PT630DHD0L00B, PT630DLR2L00B, PT630DWA2L00B, pt630hd-0l00b, PT630HD2L00B, pt630wa0l00b, pt630wa3l00b
Unitech Contact Information
Main support number714 892 6225
Support FAX1 (714) 892 8605
Email supportinfo@unitech-na.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
