FixYa.com
Unitech PA962 Portable Terminal
All Products > Unitech > Barcode Scanners
Problems with Unitech PA962 Portable Terminal?
Search inside Unitech PA962 Portable Terminal Knowledgebase
Troubleshooting and Support
Solved Problems for Unitech PA962 Portable Terminal RSS Feed Post a New Problem
Unitech PA962 Win 4.2 and CF 2.0
Hallo, do you have someone some experiences with installing Compact Framework 2.0 SP1 to Unitech PA962 device? The...
6 Solutions
Problems with BHT scanner
when downloading data to BHT (new lookup) it starts to transfer some information and then stops, and 'File transfer,...
1 Solution
change region code on my apple mac
I have bought a DVD from Amazon and can't play it because I can't change the regio code on my computer - how do you do...
1 Solution
distributors requiring isbns when my CDs...
I have been seeking a distributor for my music products, initially three CDs. Because the CDs only have bar codes, is...
1 Solution
barcode scanner for Verifone Omni 3750
Hello ! I'm trying to find the right barcode scanner for Verifone Omni 3750. Can you give me some tips? I'm looking...
1 Solution
Optical Drive not working.
Hi! I use a Toshiba Tecra M5 notebook & it has MATSHITA DV RAM optical drive. This device is not working & the...
1 Solution
DS6708 symbol scanner freezes keyboard
Hi I was using this scanner for a few hours but we changed a few settings (by scanning barcodes from the manual). The...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypePortable Terminal
InterfaceRS-232
ConnectivityCordless
Optical
Light Sourcevisible laser diode (VLD)
Scan Rate39 Scans per second · 42 Scans per second
Pitch Angle53
Technical Features
Special FeaturesColor Display, Keypad, Upgradable Flash Memory · Color Display, Backlit Keypad, Upgradable Flash Memory
Decode CapabilityEAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Interleaved 2 of 5, MSI Plessey, Standard 2 of 5, Code 11, Code 32 · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, ISBT 128, Code 128, CODABAR, Interleaved 2 of 5, MSI Plessey, Standard 2 of 5, Code 11, MSI, Code 32
Environment protectionIP 54 (Water and Dust Resistent), Humidity: 5% - 95% non condensing
Battery
BatteryRechargeable, Lithium-ion
Dimensions
Depth1.7 in.
Height7.28 in.
Width.97 in.
Weight.97 lb.
Warranty
Warranty1 Year
Supported Models
PA962920AC, PA962920AD
Unitech Contact Information
Main support number714 892 6225
Support FAX1 (714) 892 8605
Email supportinfo@unitech-na.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
