20 Most Recent Starbucks Saeco Italia Digital Barista Coffee Machine Questions & Answers
http://pdfdatabase.com/saeco-italia-service-manual.html
manual above
http://www.schwer.us/journal/2004/10/03/hacking-the-starbucks-barista-digital-italia-espresso-machine/
http://search-manual-online.com/download/manual/Perfect%20Italian%20espresso%20coffee%20-%20Spidem%20-%20Perfect%20Italian/aHR0cDovL3NwaWRlbS5pdC9pbWFnZXMvc3BpZGVtX2VuZy5wZGY
Copy/paste above to address bar.
http://search-manual-online.com/saeco-digital-italia-espresso-manual.html
lots of coffee tips for it.
Starbucks Saeco... | Answered on Dec 28, 2018
What is the model of your machine?
Starbucks Saeco... | Answered on Apr 26, 2017
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Its probably a loose hose or a failed O ring. You can take it apart and probably find the problem and fix it if you are handy. As it is don't use it. It's dangerous. You cold get a shock. Unplug it and either repair it or take it in to someone who handles Saeco. Their website lists repair facilities.
Starbucks Saeco... | Answered on Jun 03, 2016
Hi
Turn the + / - knob in the bean hopper to the + and then back 1 mark. Are the grounds coarse or fine? They should be like coarse sugar through your fingers. If they are very coarse that can be part of the problem. What is your setting on the big knob. It should be around 8 depending on your bean. Only turn the big knob down when the grinder is grinding. You can turn it up any time.
Starbucks Saeco... | Answered on May 04, 2016
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Starbucks Saeco... | Answered on Jan 17, 2016
i had this same problem and it turns out a small mineral deposit was lodged in the water line, right before it went in to the second heater (to make steam). The cost to repair and shipping was pretty high, so i fixed it myself and it's not too hard. You can try de-scaling. If you want take the water line apart, let me know and I'll walk you through it.
Starbucks Saeco... | Answered on Jan 14, 2016
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Starbucks Saeco... | Answered on Jun 03, 2015
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
I had this problem too. I was beside myself wondering what to do. I took the machine apart but there was nothing wrong. It was stuck in an infinite descale cycle. The 5 green buttons never blinked to say it was done. What finally fixed it was to close the steamer valve to where water was being being restricted from the steamer wand but still a little water was spurting out. It finally quit emitting water and the 5 lights blinked and the infinite descale cycle completed. This model espresso maker was a lemon and been nothing but problems.
jeff
Starbucks Saeco... | Answered on Nov 11, 2014
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
www.CeriniCoffee.com
Starbucks Saeco... | Answered on Oct 25, 2014
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
292 questions posted
Top Starbucks Coffee Makers & Espresso Machines Experts
Pierre Laplante
Info2011
Level 1 Expert
Steve Allison
Steve Allison
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Starbucks Coffee Makers & Espresso...
  • Starbucks Coffee Makers & Espresso...
Most Popular Question
lost leak proff lid 30 starbucks travel
  • Coffee Makers & Espresso Machines
