20 Most Recent
Memorex 24x Dvdrw Drive With Lightscribe - double-layer - Dvdr/rw - Usb - Questions & Answers
Can my memorex mvdp1075 connect to computer to read a data disk?
an old portable DVD player. IT IS.
and you want to use it as slave to PC, well does it,
does the manual cover that, ?.
but no PC stated by you making any guess, wrong. easy.
https://lmgtfy.com/?q=memorex+mvdp1075+manual
page 13 in your manual; stated, it only connects to TV
but we all know that some PCs have S-Video input jacks.
if the PC is desktop and you add the card that has that , that is.
NO PC told, there fore no possible answers , not exact and what parts to buy to do that.
2/14/2020 1:21:12 PM •
Memorex...
Answered
on Feb 14, 2020
MRX-250PH-SLVR
external 2.5": HDD .
yes and no. (no means PnP is magic)
but no PC stated, and posted to computers not TV nor Cell phones.
so in windows world of PCs we have internet working first
and then plug and play can actually work.(function).
then on your unstated PC try all USB ports, some crummy old laptops have only 100mA of current on USB ports and fail to run the motor with weak power like that.
NO PC stated. see?
The next thing I do with USB connected, is listen to side of case for the motor inside to spin, if silent that means the USB port is dead. (or drive is dead but I test the drive on other PCs so know it is not dead.)
ok it spins.
then disk manager is next, go there, and give it a drive letter.
if not done this step , explorer can't see the drive.
above manager can not see the drive, then use Device manager.
if missing there?, this external drive the USB port is dead or Microsoft does not support this drive or the drive is dead.
learn to test devices like this on 2 PCs to learn If it is good or not first. no lack of PCs on earth so have at it.
7/3/2019 12:36:46 PM •
Memorex...
Answered
on Jul 03, 2019
How do I clean the laser on a Memorex CD mini stereo with a 3cd changer
It is not even sure your laser is dirty. Perhaps you only have some bad CD's?
Does it also skip, with real music CD's. I mean the ones that are not burned in a computer. Not all self mad disks are good enough to be played and not all players can handle the self produced disks.
The cleaner you could use, is a CD, with a little brush glued on it. Don't try to make one, just buy one.
See the little red bus to the left of the middle.
11/18/2014 9:52:56 PM •
Memorex...
Answered
on Nov 18, 2014
CD spins but will not play
This will be due to the cd drive not being able to 'read' the disk correctly. Make sure the CD is spotless look for finger prints or scratches, if there are none, look to invest in a cd drive cleaning disk, ideally one with little bristles. Cd drives are relatively cheap though consider replacing it. Try other CD's..
12/9/2013 10:10:24 AM •
Memorex...
Answered
on Dec 09, 2013
Asus laptop dvd drive not working
Click start control panel administration tools computer management device manager scroll to cd/dvd rom
you might see a yellow question/exclamation ? !or a red X right click to update driver
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
12/6/2013 5:32:26 AM •
Memorex...
Answered
on Dec 06, 2013
