20 Most Recent HP LaserJet Pro P1102 Questions & Answers
Go to www.hp.com/support and let the site auto detect your printer and download the driver automatically
HP LaserJet Pro... | Answered on Jun 12, 2019
Try reading this info here
http://www.laserquipt.com/support/idx/0/463/article/501-Fuser-Error.html
lots steps to try -- from very basic to very intense -- good luck and I hope this was any help -- wicc --
HP LaserJet Pro... | Answered on Nov 17, 2017
#1-Remove the ink cartridge and use a q-tip and alcohol to clean the metallic portion of the cartridge. Gently slide the q-tip back and forth across the ink distribution openings, ink should cover the q-tip. dab dry with a paper towel and replace into the printer. #2-With the ink cartridge removed...Check the prongs on your printer that press against your ink cartridge when in place for connectivity. If covered with dry ink, use said q-tip and alcohol to clean. #3-replace the ink cartridge with a new one. Be careful, and gentle with your q-tip, rub easy, and let dry before proceeding. Be safe...and have plenty of paper towels on hand.....wear rubber gloves.....
HP LaserJet Pro... | Answered on Feb 17, 2015
SOLUTION: Follow the steps listed below:
  1. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  2. Try a different power cord. DO NOT use extension cords to plug the printer in.
  3. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  4. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  5. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. Carefully remove the fuser; IT MAY STILL BE HOT USE CAUTION. Examine the fuser, if any damage is apparent the fuser may need to be replaced. If no damage is noted reinstall the fuser, plug the printer back in and power it up.
For More info Source... Hp Error Code 50 Service Errors 50 Fuser Printer Repair
Thanks,
HP Printer Support
HP LaserJet Pro... | Answered on Jun 26, 2014
Have you installed the latest software version of HP Scan on your computer?
Heres a link to the HP instructions on how to scan multiple pages using the document feeder.
https://support.hp.com/us-en/product/hp-deskjet-ink-advantage-2130-all-in-one-printer-series/7174559/model/7174560/document/c03466081
HP Office... | Answered on Jun 19, 2019
HP LaserJet Pro P1102 Logo
Popular Tags
9 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
50 0 fuser eror
  • Office Equipment & Supplies
