Reddy R70ET Utility Heater
Problems with Reddy R70ET Utility Heater?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Reddy R70ET Utility Heater RSS Feed
Click here to get instant support from our best Experts!
View More Results for Reddy R70ET Utility Heater
Questions and Unsolved Support Problems
Unsolved Problems for Reddy R70ET Utility Heater RSS Feed
Answer
won't stay running replaced optical sensor cleaned and checked pressure and cleaned
Answer
Have Reddy Heater Pro 10 Mod. R70CT Starts and lights fine, but shuts off and kicks breaker. can... (More)
Answer
i have a pr155000 reddy heater need to in install a new tank to se the burner on top what tools are... (More)
Answer
Pilot is lit, but wont kick on when i raise the themostat, replaced the themostat and low voltage... (More)
Answer
we have a gas wall heater, pilot is lit, but it won't ignight. How do we tell if the theromstadt is... (More)
Find a Manual
Reddy R70ET Utility Heater Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Reddy R70ET Utility Heater
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
How a furnace operates and what you can do to troubleshoot.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the... written by Therinnaiguy
Trouble shooting your gas Furnace
If you are having trouble with you gas furnace they are really not that complicated to figure out. Most of the newer gas furnaces within the last 10+... written by moyerboy2
heater controls
I hear about alot of problems that people have with heaters. Some may be electric and some gas. I am going to give up a few ideas that were given to... written by tdulany
how to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the... written by kellys4640
Cruise Control for Your Oil Burner to Save Money
The Beckett HeatManger is a microprocessor controlled device that will manage the on/off cycles of your boiler. Every time your boiler has to shut... written by heatman101
Cleaning of flame sensors
In my experience I have seen many people use sand paper to clean the flame sensors on furnaces. It is best to use a small stainless steel brush to... written by Robotinner
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of... written by heatman101
How to make sure you Heat is working
A common problem with a furnance is the furnance will attempt to ignite, several times, you will notice that the house is not heating properly. You... written by melvinbracey
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Reddy R70ET Utility Heater
Nationwide | 8009059506 | Website
Traditional water heaters use a storage tank to hol... Read More
Featured Listing
Nationwide | 8884489872 | Website
Nationwide plumbers where ever you need us any tim... Read More
Featured Listing
Nationwide | 866 3278928
Ratings for the
Find a Warranty
Specifications for Reddy R70ET Utility Heater
Key Features
Type
Utility / Portable
Features
Thermostat
Power Source
Gas
Fan Forced
Fan Forced
Safety Features
Safety Features
Automatic Shut-Off
Power
BTU
70,000 BTU
Dimensions
Depth
12 in.
Height
16 in.
Width
30 in.
Describe your problem:
Top Heater Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
