Troubleshooting & Support
Hot Topics:
Problems & Solutions
Need to know how to
Lock Mode (Quick) Use Lock Mode to prevent others from using your phone. 1. In Standby Mode, to activate Lock Mode quickly, press (for 3...
phone only vibrates no ringer at all
press the * key
Phone works while on the charger, but shuts off
I suspect you battery needs to be replaced, they are real bears these batteries muck up all the time, they appear OK, but won't work....
How to unlock LG VX4400
Many people never program a password code to "Unlock" this phone, but can lock themselves out by pressing the # key for more than...
Silence Mode
hold down the * key til u see normal mode at the bottom of screen
manner mode
the microphone button works with the phone closed. with the phone open, press and hold the * key (about 2 seconds) it will cycle from manner...
I have never used the
Most phones have a default lock code that is like 1234, 0000, or 1111. If you contact your phone service provider,t hey should be able to...
i can text my friends but i can't receive...
d problem is with network
LG VX4400 Can't get the ringer to turn on.
HI Just try these steps it should be ok 1 . P ress Soft Key 1 Menu. 2 . P ress key 8, key 1,key 1. 3 . Select Caller ID key 1, No Caller ID...
My LG vx4400 cell phone does not seem to send...
The possible problem of your phone is the mic. You can try to put headset with mic to try it. Hope it helps. If when you use headset then it...
cell phone
the firmware may need to be reflash
Unlocking LG VX4400
I heard *228 might work..but it might be an activation code..not a reset code. I'm going to try it.
2 5 8 keys do not work
Hi, Try doing a master reset on the phone and if that doesn't help then there is a malfunction with the board under the keys or dust...
Volume is non-existant on LG VX 4400
When you press vol up & down it will indicate "ringer ear jack." This means the phone is stuck in ear jack mode expecting a...
-car kit-
Throw the menu search the profiles and change it to general instead of -car kit- it will be as before.
Unsolved Problems
how do i turn off silence all?
I have no ringer sound..also it says its on vibrate and high and it doesn't vibrate either..i can't get...
i went to settings.. then
i went to settings.. then system.. and i changed it from automatic b to NAM 2 ... now when i turn my phone on.. its off...
Turn the Manner mode off
Turn the Manner mode off on the LG4400
How do I reset the
How do I reset the lock mode because I don't know the pasword
how do I unlock my
how do I unlock my vx-4400
I accidentally locked my phone
I accidentally locked my phone and I can't remember my code.
How do I adjust the ear volume on my LG VX4400. I
How do I adjust the ear volume on my LG VX4400. I can barely hear people talking to me.
Want to put my phone number in a used phone in the
Want to put my phone number in a used phone in the "My phone number area"
Upload a manual for LG VX4400
What's your problem?
Fix-O-Meter
4,238
4,238 people have viewed this product
- 49 people asked about this product.
- 17 people found solutions for this product.
- 1 person has added this product.
How to...
How to...
1000000% FREE...
